Hi
I've got Pioneer 104, which is supposed to write at 2 speed, I am using unbranded generation 3 media (vivastar), and nero 5582. I have updated the firmware for the dvdr drive, but it still will only write at 1 speed, what determines the write speed, is it something on the disc, or something else?
Hello,
I have the same problem with my Pioneer A04.
Im using Memorex DVD-R (5 movies burned with no coasters) BUT only lets me burn at 1X.
When I first got the burner and tried the included Pioneer DVD-R it le me burn 2x. Does the burner determine which dvd-r brand can use 1x or 2x?
James -
yup, currently there are only a couple of brands that are certified to burn at 2x by Pioneer, all other burn at 1x regardless. Unless you use the hacked firmware that lets all brands burn at 2x (I've not used it so I can't say if it's good or bad)
The pioneer A04 writes at 2x on media whose manufacturer code is in the firmware. if the media is not listed like vivastar then it will only work at 1x, this is the list for firmware 1.33
PVC001001
MCIG01
TDKG010000d9
MCC 00RG200
MXL RG01
TDKG02000000
MEI 00V001
TAIYOYUDEN
CMC MAG. -
I have just got a pioneer 104 firmware 1.33 and am using nero 5.5.9.1.7 and the write tab only shows 1x write why does it not show 2x write as well?
This is even when no blank media is in the writer.
I have not used any 2x media yet is this the reason why nero shows only 1x write. -
NERO will only show the 2X when the burner says that 2X is an option (ie, approved media).
http://81.97.231.148/pioneer2x4all/ Look at the bottom of the page.
Hope this helps
SmurffTo all those past and present. All those that have fought for our freedoms. God Bless. Those of you that are fighting now,
keep your heads low. Those of you back home hold your heads high. -
Interesting......
Thank you Very Very much for the Link
Does anybody updated the A04 with this firmware? Does it work well or it causes problems???
Thank you
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 19th Oct 2013, 23:25 -
Write Speeds - anything new?
By Mike99 in forum MediaReplies: 22Last Post: 10th Feb 2009, 19:41 -
DVD burner read/write speeds
By ecc in forum Authoring (DVD)Replies: 9Last Post: 13th Apr 2008, 05:49 -
Is it safe to write on DVDR BEFORE burning?
By snowbound in forum Authoring (DVD)Replies: 6Last Post: 23rd Mar 2008, 20:29 -
PAL DVDR to NTSC DVDR including menus + extras? Is there an easy way?
By junkmonk in forum Video ConversionReplies: 3Last Post: 13th Mar 2008, 23:19
