Hi all
My process is DVDDecrypter, DVD2AVI,TMPGEnc then finally Nero 5.5.
My first go was successful but when I played it back on my standalone DVD it stretched the picture to full screen so everything looked skinny. The DVD is set to 4:3 letterbox so 16:9 dvds don't look skinny.
Is it because I changed the A/R to 4:3 instead on leaving it as 16:9?
What are the settings for doing a wide screen movie and full screen movie so it looks normal on my 4:3 TV, and what part of the process do I make the changes in?
Is there a program that fits inbetween TMPG and nero for adding chapters and the like to my SVCDs?
Thankyou!![]()
If the source DAR = 16:9 (16:9 anamorphic movies as well as essentially all 2.35:1 movies -- which are 16:9 DAR + letterboxing), then select the source as 16:9.
The destination aspect ratio should always be 4:3 for SVCD.
As for making chapters, you will want to use VCDImager. I suggest using VCDEasy as a GUI for the beginner.
http://www.vcdimager.org
http://www.vcdimager.org/guides
http://www.vcdeasy.org
Regards.Michael Tam
w: Morsels of Evidence -
I downloaded VCDimager but it said cgywin1.dll file was missing when I tried to run it. A re-download didn't fix it.
Ideas? -
Where did you download it??
I should come with all the necessary DLL files.
Also, if you download VCDEasy, I suggest that you get the "Full Installation".
Regards.Michael Tam
The missing file is in the download . When I click the application it falshes up for second then closes.
I don't know! -
When you unzip the zip file, make sure you unzip all the files into the same folder.Originally Posted by scottb721
Furthermore, VCDImager is a command console application which means you will have to use it from the command console.
Thus, my suggestion of using VCDEasy. It is easier for the beginner.
Regards.Michael Tam
avidemux - x264/mkv with chapters? + aspect ratio question.
By simon_h in forum DVD RippingReplies: 2Last Post: 22nd Nov 2011, 15:13 -
Aspect Ratio Problem
By prismpecs in forum ffmpegX general discussionReplies: 1Last Post: 25th Oct 2011, 14:36 -
By kumaresh in forum Video ConversionReplies: 0Last Post: 5th Jul 2011, 06:42 -
By maccool111 in forum Video ConversionReplies: 6Last Post: 29th Mar 2010, 08:58 -
PAL SVCD - Optimal resolution for preserved aspect ratio?
By Gew in forum Authoring (VCD/SVCD)Replies: 7Last Post: 27th Feb 2009, 15:25
