OK. I don't think this was happening before and I'm not sure what happened.
Mods....if this is the wrong spot please move this.
I did a capture @352x480 using picvideo mjpeg set to 19 with v-dub. Tried to load the cap into v-dub via AVISynth when I was done and it crashed bigtime. no warning or error just up and disappeared from my screen. I don't have this problem using AVISynth when I cap with either morgan mjpeg or huffy which are the others I use the most. I can't quite remember if I tried this before and it worked.....seems to me that I did. Anyone else have a problem like this? Or know a workaround? Thanks!!
Had some similiar problem with PicVideo MJPG. VirtualDub couldn't find codec instead of crashing, although captures play well on WM player. Solution: select PicVideo MJPEG as the primary MJPEG codec and check "Enable Codec" box when you press the configuration button. Seems to be working all right after that. But I rarely use MJPEG codec, so my memory might serve me wrong.
aaaaaaaaaaaaaaaaaaahhhhhhhhhh
I feel like a dumbass now. After you said that I remember some warning that I got when I re-installed both picvideo and mjpeg. Can't remember exactly what it was, but very similar to what you're saying. Thanks man!!!!
DVD to AVC High Quality PSP Videos using Avi synth
By ppeterr in forum DVD RippingReplies: 12Last Post: 18th Jul 2010, 09:03 -
Combining and converting AVI (MJPEG) files
By vikasa in forum Video ConversionReplies: 0Last Post: 21st Jun 2010, 13:47 -
Convert AVI to Mjpeg-II or other format
By hemang in forum Newbie / General discussionsReplies: 4Last Post: 12th Nov 2009, 08:23 -
prerendered subtitles on MP4 or MJPEG-AVI
By pokerpoker in forum SubtitleReplies: 2Last Post: 6th Sep 2009, 15:06 -
VOB to H264 MKV (AVI Synth and audio delay help)
By PsyCLown in forum Video ConversionReplies: 1Last Post: 20th Feb 2009, 02:52
