UNder TMPGENc wizard, under Quatnize Matrix, should I check floating point DCT? This is for converting from divx to svcd.
-- The Newbie GuidesUse floating point DCT: If you've ever made a VCD that shakes at the top when it gets real bright next to the letterboxing, this will help to calm that.Hello.
Mocha, just to be safe, always select "Use floating point DCT" under the Quantanized matrix tab.
TMPGEnc Xpress - Clip Settings - No setting for 8:9 PAR
By terpsfan101 in forum Video ConversionReplies: 13Last Post: 17th Jun 2012, 05:28 -
Help - invalid Floating point operation!!!!
By Pintocas in forum AudioReplies: 1Last Post: 15th Sep 2010, 10:28 -
TMPGEnc 4 Divx Setting
By Anakin in forum Video ConversionReplies: 2Last Post: 14th Oct 2009, 17:21 -
r6002 floating point error with MPC , maybe
By BWMagus in forum Software PlayingReplies: 5Last Post: 19th Mar 2009, 09:08 -
MPC Runtime Error, 6002 floating point support not loaded.
By Leo99 in forum Software PlayingReplies: 5Last Post: 24th Nov 2008, 03:22
