I have tried everything with ffmpegx to burn an svcd. Each time, I end up with at 400+ mb file, that looks great. There may be a little problem at the end.. with sync, but each time I burn, and when I try to play on the player, I can see the numbers on the timer of the DVD Player ticking by very rapidly. and nothing playing on the screen.
What would be the settings, that I can change that might allow this dvd player to play SVCD? or does it..
what kind of APEX DVD u got?
its usually located underneath the cdtray of ur player.. once u knew what model it is go here http://www.vcdhelp.com/dvdplayers search for ur player see if it supports SVCD...
Well most of the APEX models should support that format but im not sure about that.. hope this helps..
:^)I FEAR NO BEER!!!
How to add audio(.mp3) & adjust in video(.mkv) & burn in vbo ?
By ashe09 in forum AudioReplies: 0Last Post: 16th Jul 2011, 04:06 -
store video & also burn chapters according to datestamp (vista & dv
By Nicola-Pickle in forum Newbie / General discussionsReplies: 2Last Post: 4th Apr 2009, 08:08 -
Help! Apex 5131 Will Not Play DVD
By NautTboy in forum DVD & Blu-ray PlayersReplies: 2Last Post: 24th Dec 2007, 12:33 -
i can't burn cd & dvd
By dhaval942 in forum MediaReplies: 2Last Post: 10th Oct 2007, 12:29 -
Burn Software with Menu & burn xvid avi
By CynthiaBlue in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2007, 21:46
