I am using DVD2SVCD w/CCE 2.5
I switched back from 2.64 Because it seemed from what I read its more stable..
Anyway I first chose one chapter, ripped w/ 2pass vbr, Didnt downsize the audio (kept it at 48 ).. And it came out nice..
I was happy!!
So before I left for work I started the process of ripping/encoding the whole dvd..
I thought since I would be away, I'd go for a 3 pass VBR..
This was 1pm, I just got home at 10pm and HOLY COW, its still got 7 and 1/2 hours left to encode..
16 and 1/2 hours, is that right??
WOW..
I am gonna post the log as it stands at end of message..
Please look at it and tell me what I could do to speed it up..
I know the obvious (use less passes), but is there anything else?
My computer Specs are in Profile..
Btw the movie is Mallrats-- So I guess 3 pass was overkill since there isnt any high motion to speak of..
Opinions greatly appreicated, Thanks in Advance..
WNASPI32.DLL 4.6.0.1021
- 11/8/2002 1:00:56 PM
- DVD to SVCD Conversion
- DVD2SVCD ver. 1.1.0 build 1
Initializing
Initializing finished.
- 11/8/2002 1:01:00 PM
- Free on drive C: 19143.99 mb
- Internal rip
Preparing vobfiles to be ripped:
- D:\VIDEO_TS\VTS_04_1.vob
- D:\VIDEO_TS\VTS_04_2.vob
- D:\VIDEO_TS\VTS_04_3.vob
- D:\VIDEO_TS\VTS_04_4.vob
- D:\VIDEO_TS\VTS_04_5.vob
Ripping: D:\VIDEO_TS\VTS_04_1.vob
Ripping: D:\VIDEO_TS\VTS_04_2.vob
Ripping: D:\VIDEO_TS\VTS_04_3.vob
Ripping: D:\VIDEO_TS\VTS_04_4.vob
Ripping: D:\VIDEO_TS\VTS_04_5.vob
Ripping finished. Speed: 2898
- 11/8/2002 1:21:50 PM
- DVD2AVI
Creating DVD2AVI INI file:
- C:\Program Files\DVD2SVCD\DVD2AVI\DVD2AVI.INI
Variable settings:
iDCT_Algorithm: 32-bit SSE MMX
Executing DVD2AVI.
Executing DVD2AVI. Commandline:
"C:\Program Files\DVD2SVCD\DVD2AVI\DVD2AVI.exe" -CS=2 -YR=1 -EXIT -OF=[C:\Program Files\DVD2SVCD\Movie\DVD2AVI_Project_file] -IF=[C:\Program Files\DVD2SVCD\Movie\VTS_04_1.vob,C:\Program Files\DVD2SVCD\Movie\VTS_04_2.vob,C:\Program Files\DVD2SVCD\Movie\VTS_04_3.vob,C:\Program Files\DVD2SVCD\Movie\VTS_04_4.vob,C:\Program Files\DVD2SVCD\Movie\VTS_04_5.vob]
Analyzing DVD2AVI Project file
Hybrid Film activated. IVTC will be applied and will slow down the entire process!
Framerate: 29970
DVD2AVI processing done.
- 11/8/2002 1:24:28 PM
- Free on drive C: 15670.76 mb
- AUDIO Extraction
Found AC3 stream id: 0x80
Filename: C:\Program Files\DVD2SVCD\Movie\Extracted_audio_1.ac3
Audio1 delay: 24 ms
Audio extraction finished.
- 11/8/2002 1:28:50 PM
- Free on drive C: 15368.61 mb
- AUDIO conversion
Encoding Audio. Filename: C:\Program Files\DVD2SVCD\Movie\Extracted_audio_1.ac3
Executing BeSweet. Commandline:
"C:\Program Files\DVD2SVCD\BeSweet\BeSweet.exe" -core( -input "C:\Program Files\DVD2SVCD\Movie\Extracted_audio_1.ac3" -output "C:\PROGRA~1\DVD2SVCD\Movie\Encoded_audio_1.mp 2" -logfile "C:\PROGRA~1\DVD2SVCD\Movie\Encoded_audio_1.lo g" ) -azid( -L -3db -c normal -s surround -g max ) -ota( -d 24 ) -2lame( -e -b 192 -m s )
Audio conversion of C:\Program Files\DVD2SVCD\Movie\Extracted_audio_1.ac3 finished.
Audio conversion finished.
- 11/8/2002 1:48:19 PM
- Free on drive C: 15239.05 mb
- Video Encoding using Cinema Craft
Executing Cinema Craft Encoder.
StreamSectors: 1542373728
AudioSectors: 139426056
VideoPAPO: 21732408
ScanOffsetBytes: 164711
SeqAligningBytes: 10468286
DVDBytes: 0
VideoEndHeader: 8
SubtitleSectors: 0
EmptySectors: 238.00
PictureSectors: 1.00
PureMPEGStream: 1370582258.80
Seconds: 5731.85
CalcMPEGStream: 1370582258.80
Frames: 137259
CDSize: 740.00
Number of CDs: 2
Cut point 735.00
Variable Settings:
Frames: 137259
Anti Noise Filter: 2
Passes: 3
Image Quality: 17
VAF file creation: On
Video Encoding Mode: Multipass VBR
Min. bitrate: 300
Max. bitrate: 2530
Avg. Bitrate: 1912
Aspect Ratio: 16:9 (borders added, encoded as 4:3)
---AVS Begin---
LoadPlugin("C:\PROGRA~1\DVD2SVCD\MPEG2Dec\mpeg2dec .dll")
LoadPlugin("C:\PROGRA~1\DVD2SVCD\INVERS~1\DONALD~1 \decomb.dll")
mpeg2source("C:\PROGRA~1\DVD2SVCD\Movie\DVD2AV~1.D 2V")
Telecide()
Decimate(5)
BicubicResize(480,360,0.0,0.6)
AddBorders(0,60,0,60)
ResampleAudio(44100)
----AVS End----
something like that I would think your results from CQ single pass would be great. I read a lot about 3 and 4 pass VBR but after trying it I'm not sure that most movies warrant it. Maybe Star Wars of something with lots of fast motion. I did Tomb Raider in CQ single pass VBR with CCE2.5 with Q set to 100 and image set down to 2. OUTSTANDING results!!!!
I also noticed that it activated "IVTC in DVD2AVI"
I had it set on automatic, should I have this setting on or off -
Doing some more research I found this explanation of hybrid from Doom9's Site-
Crapola, did I pick a hybrid movie for my 1st attempt of a rip, and is that what is causing the slowdown in encoding (they say up to 40% slower)THE DREADED HYBRIDS. Many "making of" documentaries or other special features on DVD’s, and unfortunately, some complete DVDs (a very few thank goodness) are a mix of Film and Video (Interlaced) material. Here you are faced with 2 choices, neither of them pleasant. It, in part, depends on how much of each there is and how it looks with the 2 solutions. For example, a DVD made from a television show might have been created in Film, but have a few minutes of Computer Generated effects done at 29.97fps. The Anime Serial Experiments Lain has some of this. So do the infamous Star Treck: The Next Generation DVDs. So, do you IVTC it and make it 23.976fps and have the CG material play jerky? Or do you make the whole thing 29.97fps so that it will play relatively smoothly (but in the process get lower quality for the same file size because of the 25% greater number of frames)? It's a tough decision. I've seen DVD Documentaries which are made up of mostly Film material. But there will also be interlaced photographs which are frequently panned or zoomed. You IVTC these and those photographs get very jerky. Perhaps the best solution is to use Decomb's Decimate(Mode=1). This will preserve most of the progressive material and will play relatively smoothly but, again, keep it at 29.97fps. I can't tell you what to do in those cases. You’ll have to experiment and see what looks best to you.
That would be my luck--
Also real stupid question-- after Its done ripping the VOB's can I take my dvd out of my rom?
Also after the process is complete do I have to delete all the files it created in the Default (Movie) folder, or does the next project overwrite them..
Update it's 12:20 am and we are at 54%-- lol --- Only 5 and 1/2 hours to go..
THis bitch better look good!!
Honest opinions about "Magic DVD Copier"
By _yo_wasup_ in forum DVD RippingReplies: 13Last Post: 1st Jul 2009, 16:58 -
Opinions about this vhs to dvd?
By Haopengyou in forum Capturing and VCRReplies: 11Last Post: 28th May 2009, 07:47 -
opinions on method to convert DVD to MPEG2 lossless
By fotty in forum DVD RippingReplies: 14Last Post: 21st Feb 2009, 07:48 -
AAC, AC3, or Copy Stream from DVD, need opinions
By oldjoe911 in forum AudioReplies: 3Last Post: 7th Sep 2008, 12:08 -
my rip spec hell - from a ts. folder to rip specs - how?
By marinebc11 in forum MacReplies: 5Last Post: 26th Nov 2007, 21:28
