I trying to burn the movie scarface on dvd, I rip it w/clad and then encode with tmpg,but when I try to burn it to a dvd/with my dvd burner,it gives me error that says"The file is to larger than 2gb and therefore cant be stored in a ISo file system.Please use the UDF file system to write such large files"Any suggestions
Originally Posted by dreakswift
Do you expect this to play in a standalone DVD player? If so you have to author it as DVD-video and then burn. I suggest you read one or two of the ripping, authoring and/or burning guides on this site before you start making coasters. -
after encoding with TMEGEnc to a mpeg2 ( or m2v file ?), what did you author the mpg / m2v-ac3 file with ? If I am correct only 1 Gb vob files can be played back on a DVD player as that is part of the DVD specification / file structure.
Nero does not author, it just burns
for a DVD to be here are the steps ( and I am going to be basic about it ).
Assuming it over 4.3 Gb.....
1. Rip the VOB files ( thre main movie only ) to the hard drive.
2. Framse serve the vob files with DVD2AVI for TMPEGEnc,
extracting either a WAV file or a AC# file in addtion to D2V file.
3. Load the D2V file and the Wav / or AC3 filein TMPEGEnc and render away to either a MPEG2 or M2V file. If it's a M2V file then mux with the AC3 file in TMPEGEnc under tools.
4. Author the mpeg 2 file in DVD Workshop or any thoer DVD Authoring program, all that build the VOB , IFO, BUP file for the burn, most of the authoring programs burn....
5. or after the authoring program makes a new VIDEO_TS folder with the neccesary VOB, BUP, and IFO files, burn in NERO as DVD Video.
Windows Movie Maker will not all me to burn a dvd with a large video file.
By mgurksnis in forum Video ConversionReplies: 1Last Post: 29th Dec 2009, 21:51 -
Having trouble burning a DVD off of my DVR
By RRFeeney in forum Newbie / General discussionsReplies: 2Last Post: 1st Oct 2009, 14:57 -
Burning large file onto CD or DVD
By Tom in HD in forum MacReplies: 3Last Post: 2nd Jan 2009, 15:06 -
trouble converting burning movie
By bimmerboy79 in forum Video ConversionReplies: 2Last Post: 8th Oct 2008, 07:35 -
Movie too large for DVD
By poppy56 in forum Newbie / General discussionsReplies: 3Last Post: 15th Dec 2007, 16:23
