Hi,
I am trying to burn a 716MB of data onto a regular 700 MB cd-r ... is it possible? How can I do that if it is?
thanks
Use nero, select file, preferences, expert features, and select to allow overburning.
If you were making a S/VCD, with 80min/700MB media and your source files were 716 MB in total, you wouldn't be overburning. Far from it in fact. Because of the burning mode used for S/VCDs, you can fit about 796 MB of video data on an 80min/700MB without overburning.
As to your specific question on whether overburning affects the quality of the video, the answer is generally "NO".
If you try to overburn BEYOND the physical capacity of the disc, however, your movie will be truncated.
Furthermore, there is the hypothetical possibility (though it has never been reported) that the video burnt on the "overburnt" area could be of inferior quality (i.e., poorer data integrity -- more numbers of burning errors).
Regards.Michael Tam
w: Morsels of Evidence -
Thanks for the information ...
However, I am not burning it in mpg mode for to make a s/vcd ... I am just trying to burn it as data (in avi format) ... does it work the same?
thanks. -
If it's data your burning in mode 1 which limits you to 700MB. To overburn you need a CD burner that supports overburning and you need software that allows overburning. Both Nero and NTI CD-Maker support overburning. Finaly you need the 90 or 99 minute CDR's. I've only used 10 99 minute CDR's but they burned and played normally for me.
Originally Posted by wulf109
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 12:42 -
Trying to burn an mkv with subtitles, but the subtitles don't burn properly
By geramul in forum Newbie / General discussionsReplies: 15Last Post: 1st Sep 2010, 19:12 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 04:26 -
Advice required when trying to burn with img burn
By IPBR21054 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 1st Aug 2009, 16:29 -
Burn Software with Menu & burn xvid avi
By CynthiaBlue in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2007, 20:46
