I was playing around with "Fast Mpeg" and noticed that when finished encoding, the audio was synced perfectly. Is there a way to get the mpegs any smoother, or to not drop frames?
"Good Luck 007"
In Memory of Desmond Llewelyn -
There are many issues needing improvement and ffmpeg is a constant work-in-progress, so waiting for the next releases is my best suggestion for now 8)
Confused! Confused! Confused! VCR to DVD; major question Toshiba Diomage SV
By CAnn12 in forum Capturing and VCRReplies: 0Last Post: 5th Feb 2011, 11:26 -
Where is the Major... ??
By moon47usaco in forum ffmpegX general discussionReplies: 2Last Post: 12th Aug 2010, 12:22 -
Need Major help from an expert!
By jbartosh in forum MediaReplies: 38Last Post: 23rd Oct 2007, 12:45 -
Major 'Codec' Problem
By mattstan in forum Newbie / General discussionsReplies: 4Last Post: 25th Aug 2007, 15:18 -
major problem
By Antitrust19 in forum ComputerReplies: 6Last Post: 28th May 2007, 08:30
