I've had a few problems ( like most newbies ! ) with sync problems when I'm converting a DIVX file to VCD
One of my problems seems to be that the DIVX source has about 40 seconds of audio silence before any sound begins . Whenever and however I strip the audio stream this silence does not seem to be converted and hence when I merge my audio back to my video in TMGEnc the audio starts without any silence and my film is out of sync
I tried using the original audio and video streams in TMGEnc but again the same result
I have put the 44 seconds of silence back into the audio track using Goldwave but is this always the case ?
Any advice would be appreciated
For Info the audio compression used in the film was MPEG LAYER 3 CODEC ( professional )
Cheers
Fred
Results 1 to 1 of 1
Add silence to beginning of track
By CSULB71 in forum AudioReplies: 3Last Post: 10th May 2010, 17:04 -
Inserting silence batch style!
By Jo The Veteran in forum AudioReplies: 3Last Post: 11th Sep 2009, 14:58 -
Remove Silence from large WMV's
By djbryson in forum EditingReplies: 3Last Post: 4th Jul 2008, 09:53 -
Spliting Audio Based on silence
By loster in forum AudioReplies: 4Last Post: 30th Aug 2007, 09:27 -
NON-COPYRIGHTED silence?
By saturndude in forum Newbie / General discussionsReplies: 15Last Post: 29th Jul 2007, 18:55
