first i extract the mpeg from the vcd
then i use tmpeg to convert to mpeg2(pal)
then i use powerdirect pro or ulead dvd factory to author but keep getting the same problem.plays fine on the pc,but i get jittery playback and a large black strip along the top of the picture on my standalone dvd.
i have read the guides on this site and can`t see where i`m going wrong
can anyone help please
tmpeg to convert to mpeg2(pal)Waht is the framerate of the original. A lot of the VCD's around are encoded in NTSC framerate which is 29.97fps.Some are NTSCfilm at 23.97fps. Converting these to PAL at 25fps by simply re-encoding in Tmpgenc will cause jittery playbacl.but i get jittery playback
If 29.97 fps, just convert the audio to 48khz, re-emux and author. If the mpeg is 23.97fps I am not sure what is the best way to get it to 29.97fps. I know 3:2 pulldown is the answer but am not sure how to apply it without re-encoding.
Don't worry about it being NTSC. All european DVD players will play them. You either set the player to output PAL-60 or NTSC. Your TV should accept one of thes if not both, unless it is VERY old. -
Also, make sure you set the "MAX number of frames in GOP" to 18 (NTSC) or 15 (PAL) to be fully compliant along with 48000Hz audio frequency.
Hope That Helps you, canny!!!
:P
VCD is mpeg1 and can be imported into DVD without re-encodeing to mpeg2. Mpeg1 is part of DVD standard.
tried to read the disk in pal and nstc,but didn`t make a difference
any other tips please -
But which disk, the ones you converted as described inyour firts post? If so it won't matter what setting you have your DVD player on, you have already done the damage converting from NTSC to PAL as you described. Re-encode in NTSC if the original AVI is 23.97 or 29.97 fps. Thats how to fix the problem.Originally Posted by canny
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 20:32 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Help with VCD to DVD
By bwheeler in forum Newbie / General discussionsReplies: 9Last Post: 28th Jun 2007, 03:25 -
Dvd to Vcd
By tryst1 in forum Video ConversionReplies: 2Last Post: 5th Jun 2007, 02:30 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
