Which is likely to produce better results for viewing on tv?
1) mpg2 at a low bitrate
o2
2) mpg 1/2 at a high bitrate
Results 1 to 9 of 9
It's impossible to tell without more specifics...
resolution, bitrate, max bitrate ( if vbr ), source, filters, ......
Generally in sweeping terms at the same resolution and frame rate a higher bitrate will improve quality. -
OK more specific. I'm writing a DVD. To fit all content on 1 disk do I
1) use mpg2 at 3-4kbps
2) use mpg1/2 at 6-7 kbps -
Originally Posted by miketree
the length of the video is not an issue. I only want to know the relative qualities of these two settings.
If I had a piece of video which I encoded first by method 1 and then by method 2 which is likely to look better on a tv? -
I'm assuming you're talking about full mpg2 (720x480 or whatever it is) and half D1 (352x480), right.
I believe you will use the same bitrate for either one (presumably the highest bitrate you can use to fit the length of video on your disk). You will not be able to use a higher bitrate by lowering the output size of the frames. Bitrate is bitrate, the number of bits per second in the viedo stream, and that is what determines the size of the file and length of the video you can put on a disk. At a higher resolution vs a lower resolution, you are asking the same number of bits to carry more information. But the length of the video will be the same. (BTW, forum, if I'm wrong about this, don't hesitate to let me know.)
What's your original source/capture resolution?
I rendered some clips of analog home video that were captured at 720x480 via miniDV cam to D1 and half D1, and couldn't really tell the difference between them. But I didn't capture stills and really eyeball them.
I'd be curious to hear what you finally decide.[/u] -
For myself, using clean source ( digital cable through s-video ) I have been getting...
at 704x480
Letterboxed - progressive ( 23.976 )= 1.8-3.3mbps average
Letterboxed - interlaced = 2.6-4.0mbps
Fullscreen progressive ( 23.976 ) = 2.8-4.5mbps
Fullscreen Interlaced = 3.3-5.0mbps
If your sources are noisy ( ie most cable, VHS, ... ) double the bitrate or half the resolution.
Editing MPG2
By danielmak in forum MacReplies: 16Last Post: 17th Feb 2010, 17:28 -
demuxing mpg2
By volam in forum EditingReplies: 1Last Post: 11th Jul 2008, 14:05 -
VCD MPG1 file to CD Question
By Excelsior123 in forum Authoring (VCD/SVCD)Replies: 21Last Post: 22nd May 2008, 19:14 -
avi to mpg1
By zoranb in forum MacReplies: 3Last Post: 12th Sep 2007, 14:46 -
Minimum MPG1 file size?
By Choppa in forum Authoring (VCD/SVCD)Replies: 17Last Post: 17th Jun 2007, 23:04
