Not sure if this is a the right topic as the question is sort of on 2 things but will ask anyway.
Ive recently changed from making vcds to svcds when i make them for my own pc to play them they work great, but when i make them for a friend they do not play on his dvd player (Phillips 723) they come up all blockey and pixilated. But when he makes them himself using all the same programs (smart ripper, dvd2avi and tmpgenc) they seem to play great in his system.
Does anybody know why this happens?
Do different systems give different svcd/vcd results?
Could different writers have different results?
Or does he have a crappy dvd player.
Any help would be great as this is driving me mad.
Cheers.
Doh Doh Doh!!!
What video bitrate are you using?
What Audio bitrate are you using?
What resolution are you using?
How long is the movie/programme?
How many CD's are you trying to fit it on?
As you can see, there are quite a few variables in the equation.
If you are encoding outside of the SVCD specs then they won't play on all SVCD capable machines.
GGSEat! Drink! Be merry! Tomorrow we snuff it! - (Sid James, from 'Hancock's Half Hour') -
Im using all the standard settings that come with the standard tmpgenc svcd template.
Doh Doh Doh!!! -
If your using the standard settings then I'm afraid I'm a bit stuck on this one. Have you tried using DVD2SVCD? It's really easy and gives excellent results every time.
Is your friend doing exactly the same as you? Is he making proper SVCD spec CD's?
Tell me exactly what your doing and I'll go through it myself to see what's going on. I can but try!
GGS.Eat! Drink! Be merry! Tomorrow we snuff it! - (Sid James, from 'Hancock's Half Hour')
Problems Converting AVI to SVCD
By wiseguy109 in forum Video ConversionReplies: 3Last Post: 6th Oct 2007, 14:17 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 06:18
