Hi.
This is my first post in this forum. Anyway... the question is: I'm trying to encode a SVCD witt ffMpeg ("f" vers.) but I'm getting an error at the end because it is unable to mux the tracks beacuse (sorry...) the audio track (m2a) is not available. The matter is that I do not see any encoding of the audio track on the terminal while I correctly selected an MP3 to be encoded.
This is important since I' unable to obtain a goog VCD for my Pioneer DV525 (audio is terrible).
Results 1 to 14 of 14
Here it is:
Last login: Fri Nov 8 16:27:33 on ttyp1
pbpaste | sh
Welcome to Darwin!
[Simons-Computer:~] simon% pbpaste | sh
Input #0, mpegvideo, from '/Volumes/HD-VideoEditing/SVCD/PGR.m2v':
Stream #0.0: Video: mpegvideo, 720x576, 25.00 fps, 8000 kb/s
Output #0, yuv4mpegpipe, to 'pipe:':
Stream #0.0: Video: rawvideo, yuv420p, 480x576, 25.00 fps, q=2-31, 200 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Press [q] to stop encoding
YUV4MPEG stream header written. FPS is 25
++ WARN: [mpeg2enc] Generating dummy SVCD scan-data offsets to be filled in by "vcdimager"
++ WARN: [mpeg2enc] If you're not using vcdimager you may wish to turn this off using -d
frame= 1528 q= 0 size= 618850kB time=61.1 bitrate=82945.4kbits/s
No audio or video streams available
INFO: [mplex] mplex version 2.2.1 ($Date: 2002/04/20 19:08:30 $)
INFO: [mplex] File /Volumes/HD-VideoEditing/SVCD/PGR.svcd.m2v looks like an MPEG Video stream.
**ERROR: [mplex] Unable to open file /Volumes/HD-VideoEditing/SVCD/PGR.svcd.mp2 for reading.
Encoding complete!
The audio input file is an .aif converted to .mp3 by iTunes. HTH.
TIA
Simon
Major, I'm unable to repeat the procedure because the mpeg2enc is no more available due to reparation of privileges and ffMpeg doesn't display anymore the terminal commands to install it.
Could you please submit those commands as I'm unable to get them from the mpeg2enc site?
Next time I'll write down those commands as I frequently repair privileges.
Thanks and sorry for the inconvenience.
major, no way to redo an encoding. I re-downloaded and re-installed mpeg2enc but this is the result:
Last login: Mon Nov 11 12:35:53 on ttyp1
pbpaste | sh
Welcome to Darwin!
[dhcp24:~] simon% pbpaste | sh
/Volumes/HD-VideoEditing/SVCD/PGR.m2v: could not find codec parameters
**ERROR: [mpeg2enc] Could not read YUV4MPEG2 header: system error (failed read/write)!
**ERROR: [mplex] Unable to open file /Volumes/HD-VideoEditing/SVCD/PGR_SVCD_FF.m2v for reading.
(Super) VideoCD xml description created successfully as `/Volumes/HD-VideoEditing/SVCD/PGR_SVCD_FF.xml'
++ WARN: initializing libvcd 0.7.12 [darwin5.2/powerpc]
++ WARN:
++ WARN: this is the UNSTABLE development branch!
++ WARN: use only if you know what you are doing
++ WARN: see http://www.hvrlab.org/~hvr/vcdimager/ for more information
++ WARN:
**ERROR: could not stat() file `/Volumes/HD-VideoEditing/SVCD/PGR_SVCD_FF': No such file or directory
rm: /Volumes/HD-VideoEditing/SVCD/PGR_SVCD_FF_02_pregap.img: No such file or directory
rm: /Volumes/HD-VideoEditing/SVCD/PGR_SVCD_FF.toc: No such file or directory
Encoding complete!
[dhcp24:~] simon%
Here it is:
/VideoEditing/Encoding/ffMPEG/ffmpegX\ f.app//Contents/Resources/ffmpeg -i /Users/simon/Movies/PGR_MPEG2.m2v -y -f yuv4mpegpipe -s 480x576 -map 0.0:0.0 -r 25 -an - | /usr/bin/mpeg2enc -v 0 -f 4 -a 2 -b 2500 -q 2 -I 0 -M 1 -V 230 -o /Volumes/HD-VideoEditing/SVCD/PGR_SVCD_FF.m2v; /VideoEditing/Encoding/ffMPEG/ffmpegX\ f.app//Contents/Resources/ffmpeg -i /Users/simon/Movies/PGR_MPEG2.m2v -y -vn -f mp2 -acodec mp2 -ab 224 -ar 44100 -ac 2 -map 1.1:0.0 /Volumes/HD-VideoEditing/SVCD/PGR_SVCD_FF.mp2; /VideoEditing/Encoding/ffMPEG/ffmpegX\ f.app//Contents/Resources/mplex -V -f 4 -O 0 -b 230 -o /Volumes/HD-VideoEditing/SVCD/PGR_SVCD_FF.mpg /Volumes/HD-VideoEditing/SVCD/PGR_SVCD_FF.m2v /Volumes/HD-VideoEditing/SVCD/PGR_SVCD_FF.mp2 ; /VideoEditing/Encoding/ffMPEG/ffmpegX\ f.app//Contents/Resources/vcdxgen -q -t svcd --nopbc -o /Volumes/HD-VideoEditing/SVCD/PGR_SVCD_FF.xml /Volumes/HD-VideoEditing/SVCD/PGR_SVCD_FF; /VideoEditing/Encoding/ffMPEG/ffmpegX\ f.app//Contents/Resources/vcdxbuild -q --cdrdao-file=/Volumes/HD-VideoEditing/SVCD/PGR_SVCD_FF /Volumes/HD-VideoEditing/SVCD/PGR_SVCD_FF.xml; rm /Volumes/HD-VideoEditing/SVCD/PGR_SVCD_FF.xml; rm /Volumes/HD-VideoEditing/SVCD/PGR_SVCD_FF_02_pregap.img; rm /Volumes/HD-VideoEditing/SVCD/PGR_SVCD_FF.toc; printf "Encoding complete!\a\n"
Help... tired of listening to encoded audio
By pixeltweek in forum AudioReplies: 1Last Post: 18th Aug 2010, 04:31 -
RipBot audio can't be encoded??
By crankharder in forum Blu-ray RippingReplies: 0Last Post: 13th May 2010, 15:56 -
x264 encoded mkv/mp4 transcode to xvid encoded avi
By graysky in forum Video ConversionReplies: 4Last Post: 9th Aug 2008, 19:55 -
Encoded audio is not good - Add better audio?
By NotSoEasy in forum Video ConversionReplies: 2Last Post: 7th Feb 2008, 20:05 -
ffmpeg -- encoding while muxing new audio w/out source's audio, how ?
By vhelp in forum AudioReplies: 8Last Post: 21st Nov 2007, 20:53
