Ive just tried capturing video for the first time. Ive captured from pal vhs with geforce 4 in virtual dub with picvideo mjpeg. The thing is when there is motion in the video, i get these lines:Is there anything i can do about this?
This is totally normal.
The effect is known as interlacing. You now have two options.
1, encode as interlaced ( I prefer this one personally )
2, deinterlace and encode progressive.
If you do a search on the forums you will find many posts on this effect and the pros and cons of each encode method.
Jim -
look here for more info on that. good tutorials
http://www.100fps.com -
I have a question here. I record just as it is with the interlacing then I use teliced when I do avitsvcd is this a good or bad method?
Capturing video and compressing at same time
By tyder26 in forum Capturing and VCRReplies: 15Last Post: 3rd Aug 2011, 07:18 -
Real time video capturing
By Haopengyou in forum Capturing and VCRReplies: 3Last Post: 5th Aug 2009, 02:02 -
Sounds stops capturing after ~7 minutes every time
By rmcc4444 in forum Capturing and VCRReplies: 5Last Post: 13th Apr 2009, 13:18 -
time sensitive stream capturing software?
By uglijimus in forum Video Streaming DownloadingReplies: 0Last Post: 5th Oct 2008, 00:12 -
Capturing real-time 3D (games etc) for transfer to DVD
By Overwind in forum Newbie / General discussionsReplies: 1Last Post: 3rd Nov 2007, 05:33
