Results 1 to 11 of 11
    Nov 2002
    http://www.vcdhelp.com/dvdbackup.htm
    This doesn't work because of several problems. Apparently the times has passed this article by!
    AVISYNTH can NO LONGER serve as IPCSource. NONE of the downloads (including the latest from Avisynth.org, V2.06) has the IPCSource function. While the FAQ on avisynth.org suggests later versions, their own documentation contradict that.
    [http://www.avisynth.org/index.php?page=IPCSource]
    If DVDX cannot serve as frame-server, then the rest of the steps is pointless.
    Maybe I'm doing it wrong, but I don't think so. Any one got any alternatives? I am a bit tight on HD space.
    Feb 2001
    Berlin, Germany
    Simply because IPCsource is no longer part of Avisynth since v.1.0beta6.
    It was removed due to the discussions around GPL few months ago.
    IPCsource now is an external plugin, that must be loaded with the LoadPlugin function. You will find the avisynthex.dll at http://www.videotools.net
    Nov 2002
    Guess that tip needs to be slightly updated.
    Also... the AvisynthEX.DLL is a 30-day demoware, not shareware. If you don't register by then, supposedly it stops working.
  4. Hey Truman......
    Possibly a small sample script for what this will do? Thanks!!
    entirely TOO much time on my hands
    www.easydvdcopy.net
    Feb 2001
    Berlin, Germany
    Originally Posted by easydvd
    Hey Truman......
    There is nothing special. IPCsource connects Avisynth with the Premiere export plugin.
    LoadPlugin("avisynthex.dll")
    IPCsource("filename")
    #if you want to edit with Avisynth add filters here
  6. so when DVDx gives me an avs script, I can edit to include whatever filters and resize I want? Will those avisynth settings override the ones I made in DVDx?
    www.easydvdcopy.net
    Feb 2001
    Berlin, Germany
    I have never used DVDx, but I think so.
    edit: no, it does not overwrite DVDx settings. What DVDx exports is the source for Avisynth.
    Nov 2002
    I think I got it to work now... I have to turn OFF the "create AVS file" option so it doesn't overwrite my custom version of the AVS file with that "LoadPlugin" command.
    I guess I'll go to sleep and see if I get a big MPG tomorrow.
    In case you want to know, I'm ripping my own copy of "Run Silent, Run Deep". Bought it at Best Buy along with The Great Escape in a two pack...
    Nov 2002
    Okay, when I woke up this morning, DVDX is stuck at 99.5%, and so is TMPG and the plugin. I endtasked all of them, and looked on the drive... And voila, there's this 1.2 GB MPG file, with all the proper sound and music and even subtitles.
    Now I just have to write it to the CD... Maybe I can update that guide.
    Nov 2002
    Is there a "cutting / fitting / splitting" guide here on how to fit a long MPG onto multiple VCD's?
    Nov 2002
    Never mind, I figured it out. VCDEasy has built-in MPEG tools, which can be used to edit the MPGs with cutting and merging.
