Can anybody help me. I recently tried to convert some MPEG files to VCD using Nero and have the following problems:
After conversion, one of the file appears to have only the audio remaining and the video was lost.
Another file was playing fine in the beginning but the audio was lost half way through the file but the video remains OK.
During the initial conversion, it keeps saying that the MPEG files require re-encoding and it took almost two hours to complete one single CD.
Does anybody has similar problem and how to solve it. Thanks.
I would strongly advise using a 3rd party encoder. TMPGEnc is the most popular and due to the fact that you can control the settings (unlike the auto-encoder in Nero) your output file should be of better overall quality.
I presume you have checked that the source file has audio all the way through it.
VCD Karaoke (MPEG DAT file)- removing the vocals
By tsrusa2002 in forum Video ConversionReplies: 12Last Post: 22nd May 2011, 02:51 -
How to extract each audio channel in a DAT file (from VCD)?
By coxanhvn in forum Newbie / General discussionsReplies: 9Last Post: 28th Apr 2011, 17:06 -
How to cut and join DAT Video file with womble MPEG-VCR without conversion?
By kitharass in forum EditingReplies: 0Last Post: 11th Mar 2010, 12:57 -
convert VCD.DAT/MPEG to RMVb with dual channel audio
By newbievideohelp in forum Video ConversionReplies: 15Last Post: 6th Nov 2008, 23:42 -
How to corp a dat or mpeg file to mpeg
By onlyrasel in forum VCDEasy GeneralReplies: 1Last Post: 26th Sep 2008, 23:18
