    Nov 2002
    west coast
    Hello, helpppppp
    I used DVD decrypter/IFO edit. Plays fine on the PC, so I believe it ripped fine. Using A04 DVD-r with the firmware upgraded and the latest Nero version 5.5.9.6 I was getting communication error, but cured that by turning off DMA. Now, it starts to burn, and will stall at various %'s complete (25%,13% 33%). Program doesnt lock up, just stops burning, no errors. What did burn will play in PC DVD player. I did read on Nero's site about Via busmaster driver problems. Any ideas anyone?
    Thanks in advance,
    B.
    Nov 2002
    west coast
    Update,
    It must be nero's fault. I burned an image(made with DVD Decryptor) today using Ulead Movie Factory, and it worked fine in both PC and on Apex stand alone. I am using IFOEdit,DVDImage/DLT Builder to make an image out of larger movies stripped to VOB's etc. An easier way? This seems to be taking a while.
    B.
  3. try downloading the latest Nero (5.5.9.17)... www.ahead.de
    or if its necessary download the latest via drivers.. www.viaarena.com
    or maybe try another burning prog like RecordnowMax, Prassi, DVDGearPro.. good luck
    I FEAR NO BEER!!!
    Nov 2002
    west coast
    Thanks marscable,
    Well I do have the latest nero. Actually newer than the one you said, it is 5.5.9.6, and it is the problem. I found that movie factory will actully burn to dvd, but I have tyo make an image 1st. I will hunt down some other burn software so I can try and skip the make image part. I am 3 for 3 working now, so I hate to experiment too much more and go back to making coasters like when I started.
    B.
  5. I used to have a A03 and used to use Nero 5.5.5.0 and that was that, as I upgraded Nero the coasters started, at first I thought it was the media as I was using really cheap media, but then when I was doing coasters on my Apple media which previosuly had been pretty much coaster free, I figured it might be the Nero. I pulled the drive nad installed to my other rig, reformatted and installed latest Nero along with a clean OS ( Windows 2000 service pack 2 ). I was still making coasters ( about 50% rate ). So I figure it might be cooling, that wasn't it, so then I switched to Record Max now 4.0. It seem to do better than Nero, but I evetually ditched the A03 and got a A04. so far with Record Now Max and new 2x cheap media I had a real good track record ( no coaster yet in 10 burns ). All burns have been at 2x and vobs were either 1:1 DVD Decryptor ripped (v 3130... under the 4.3 Gb mark ) or re encoded with TMPEGEnc ( v 2.52.34.129 to a m2v file ) and merged with the AC3 ( extracted n framserved with DVD2AVI v 1.76 ) and then authored in DVD Workshop v 1.3.
    So far ithis has been a winning combo. Once I get the hang of CCE I might switch over to it for my encodes.
