Im not sure if this is the correct spot to post, please forgive if it isnt
1st I tried to rip a love hina dvd(anime), which includes 4 episodes on it, only to find that they had encoded it as one entire stream, so the episodes overlapped VOB's, in other words the first VOB contained the entire first episode and a few minutes of the second episode, the second one had the rest of the second and the first half of the third and so on.
I could not work out a way to rip these straight from the DVD to seperate correct episodes, My work around was to rip it all, then use DVD2AVI to encode DivX movies and encode them as SVCD's which worked ok. My question though is there a way to rip the episodes seperately and accurately straight from the DVD in this situation? would save Me alot of time.
2nd I have tried to rip the Robocop movie from DVD, there are 3 streams available, 2 of them are incompete and one has a few scenes at the very start before the movie actually starts. The DVD has directoros cut and original movie, I suspect this is the cause of the problem, however I cant seem to rip the movie in the correct order. Once again the only workaround I can think of is some creative editing using DVD2AVI and an AVI editor. This I feel wil take some time, does anyone have any ideas about how to work this one out?
I am using PAL in region 4, the love hina is 4:3 the Robocop is in 16:9, not sure if this info will help or not.
If you have read this far thank you very much for your time, and i hope you can help me
thanks again
TheLostTimberwolf...
	The Hellsing family will purify this world...
	I would think your 1st problem would easily be solved by selecting just the chapter(s) you need when ripping.
	ok thanks
 question would then be is there a way to see which chapters i need to rip , or is it trial and error?
  The Hellsing family will purify this world... The Hellsing family will purify this world...
	What I do it pop it in my standalone DVD player and what the display (it shows what title/chapter its playing). You can probably do this on your pc with a software player too.
	if you use flaskmpeg, you can choose which version (theatrical or director's cut) you want to encode and then frameserve it into tmpgenc....(no dvd2avi)
 this also adds subs too if u want
 http://www.vcdhelp.com/dvdtovcdflask.htm
 you get to choose which angle you want (theatrical or director's cut) under the top heading of "DVD Titles"....i'm guessing the longer length one is the director's cut
 note: be sure to rip the vobs using file mode w/ ifo file, NOT movie mode....flaskmpeg needs the complete vobs as they are, no modifications that movie mode will make to it
	this link should help you with your question about having more than 1 episode on a DVD ripping issue (I was actually talking about CladDVD XP in that post)
 http://www.vcdhelp.com/forum/viewtopic.php?t=122193
  Trouble ripping DVD with subtitlesBy stig in forum DVD RippingReplies: 9Last Post: 22nd Feb 2012, 06:08
  Trouble with DVD Ripping: Need Some RecommendationsBy charmedlife417 in forum DVD RippingReplies: 9Last Post: 28th Sep 2011, 22:44
  Trouble ripping The Ugly Truth with DVD Fab HD DecrypterBy heyjjjaded in forum DVD RippingReplies: 1Last Post: 22nd Dec 2009, 15:29
  Having trouble ripping DVD to aviBy jsbenson in forum Newbie / General discussionsReplies: 9Last Post: 29th Aug 2009, 22:44
  DVD ripping on Mac - Couple of questionsBy Anonymous70 in forum MacReplies: 7Last Post: 10th Jan 2009, 06:19
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
