Im trying to encode my file using TMPGE and the kvcd ntsc film template. The problem is that my source is pal @25fps. Is there a guide that will explain in "simple" language how to convert pal to ntsc? I saw one guide that said to simply load a ntsc template,but also read that that was bad advice. Is there a program that will do it automatically?
John
not sure why it was said to be bad advice (using TMPGenc) I have done this many times without a problem.. However.. my PAL sources might have been the correct frame rate.. or my DVD player just doesnt care.. If there is an issue with the frame rate, you could always just use pulldown.exe off the tools section.
I have read most of the beginner articles but I really dont understand what 3:2 pulldown or inverse telecine are let alone when to use them.
John -
Using TmpGenc to convert from Pal's 29.97fps to NTSCfilm at 23.97 will work but TmpGenc simply removes frames from the source to get the new framerate. The better idea is to use something like avifrate to change the framerate properly. This will make it play all the existing frames but at the new speed. Of course this is a bit slower so the audio will now be aout of sync. To fix this extract the audio from the avi with virtualdub as an uncompressed wav file, load into goldwave and stretch it to the same length as the new video. Use this as the audio input to your encoder and all will be fine.
Hope this helps -
If your source and destination are both VCD, then take a look at the instructions I posted in http://www.vcdhelp.com/forum/viewtopic.php?t=122337 (I'm still working on other combinations).
Xesdeeni
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
NTSC MPEG2 file to PAL M DVD
By Ed2009 in forum DVD RippingReplies: 2Last Post: 27th Sep 2009, 23:05 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19 -
Subtitles not added during conversion of Pal to NTSC 2 avis with 2 sup file
By unity860 in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 3rd Apr 2008, 06:54
