hello,
ive heard of this problem in other posts, but wanted to verify some things.
I burned my SVCD and it came out just fine, but the subtitles were mostly obscured. I burned the same file as a normal VCD, and the subtitles appeared perfectly. Both times I used TMPG.
I have a Pioneer 343, which says it cannot play SVCD subs. Why would this be? Im just curious. Is there a way around it (i read about changing the resolution size by 5 or 10%, but wouldn't that be non-compliant with SVCD standard resolution)?
Thanks!
~kuraikat
Results 1 to 1 of 1
ffmpegX burned subtitles are missing with arabic (iso-8859-6) subtitles
By eswenson in forum ffmpegX general discussionReplies: 6Last Post: 11th Jan 2012, 09:22 -
DVD software player- raise subtitles to top of scrn/ simultaneous subtitles
By jimdagys in forum Software PlayingReplies: 8Last Post: 6th Dec 2009, 18:30 -
Converting AVI to DVD plus Subtitles (Loss of quality on subtitles)
By somenho in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 10:23 -
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 17:28 -
Help with converting DVB subtitles to idx/vob subtitles
By Talayero in forum SubtitleReplies: 8Last Post: 21st Feb 2009, 18:10
