When I try to capture a some video from a VHS it comes out choppy and blurry when i use a different compression format it is clearer and choopier or vice versa what is the best format to use
VHS is not the greatest source to capture from anyway. But I think you should try Huffyuv yuy2--> predict median with a resolution of at least 480x480.Thats how I capture from VHS. Works good for me with no dropped frames
good-luck"The software said Win XP or better, so I Installed Linux"
What is best Mac/PC Compression software or format?
By HowardNeedsHelp in forum MacReplies: 2Last Post: 10th May 2011, 00:28 -
Best compression program/format/codecs without losing quality
By adrian2055 in forum Video ConversionReplies: 12Last Post: 20th Jan 2011, 16:29 -
VirtualDub..cant set custom format or compression???
By jranaudo in forum Capturing and VCRReplies: 4Last Post: 16th Jan 2010, 11:54 -
Premiere 6.5 - unsupported compression format.
By vodmare in forum EditingReplies: 3Last Post: 28th Jan 2008, 17:51 -
Best compression format for AVI's
By Smallan in forum Video ConversionReplies: 2Last Post: 19th May 2007, 19:13
