Is there any way too just rip out the audioAc3-file
I would like too rip out 2 vertions of the audioAc3 so that I can make the movie in 2 languages
I have trued a prog named Ac3dec but it is a DOS prog and I canīt hanle it
Please help
Do you want the actual AC3 data or to have it decoded to WAV?
If you want just the AC3, I believe that you can extract just the specific audio stream with SmartRipper when you rip your DVD.
If you want to decode the audio to wave, there are a number of ways:
1. Extract your VOBs with SmartRipper or DVD Decrypter.
2. Load the relevant VOBs/IFO with FlaskMPEG 0.6+, select your audio (and video) stream and then save the audio.
3. OR you can similarly load it with DVD2AVI, choose your audio track, and save to WAV.
Regards.
Michael Tam
w: Morsels of Evidence -
Could you please explain it a bit more
I have looked at the smart ripper but I just canīt find it out and in FlaskMpgen
I canīt find out how to save only the audio I always get both video and audio
<font size=-1>[ This Message was edited by: NICKA 1 on 2001-08-22 14:27:02 ]</font> -
http://www.vcdhelp.com/dvdtovcd.htm
Stop after the step using DVD2AVI
love!
<hr>
Well vested in the following: Pinnical DC-10+, TMPGEnc, AVI_IO, VirtualDub, Flask, BBMpeg, SmartRipper, DVD2AVI
<hr>
mkv with ac3 audio -> avi with ac3 audio ? is this possible?
By Substance001 in forum Video ConversionReplies: 9Last Post: 20th Jun 2011, 23:56 -
Ripping a Track Out of an AC3 File?
By SLK001 in forum AudioReplies: 0Last Post: 18th Mar 2011, 00:10 -
Ripping AC3 Stream from a DVD File
By Surya in forum DVD RippingReplies: 5Last Post: 27th Sep 2010, 09:22 -
Avi to Ac3 user guide. How to encode the audio from an avi to ac3 .
By freebird73717 in forum User guidesReplies: 5Last Post: 9th Dec 2009, 21:53 -
FAVC re-encodes AC3 audio even when I check the "retain AC3" opti
By teapot in forum Newbie / General discussionsReplies: 2Last Post: 9th Nov 2008, 00:10
