Hey Everyone!
I just downloaded a movie and used TMPGEnc Plus to cut the movie and convert the AVI file to MPG (So I can burn it to a VCD). Well that went all fine, but when I play the video in my GE Digital Video Disc Player and the video and sound have a sync problem. The movie will be going ok then it will get all off and the video will slow down or speed up to sync again with the sound. It gets real annoying.
Well I read the turtorial on TMPGEnc and it said to use VideoDub to extract the sound and use that WAV source for the audio in TMPGEnc and that did not work ether. Is it my DVD player or am I doing something wrong?!
Thanks for your help
P.S. the Video is NTSC Film and 23.976fps according to VideoDub.
-Spyder
I've had the same problem but with TMPGEnc MUX. I have a perfectly good VCD format that I can burn straight to disc. Just to experiment, I tried MUXing it in TMPGEnc to change the heading. Shouldn't make a difference right? Wrong!!! Suddenly the perfectly good VCD had audio and video that was out of sync. By the end of 5 minutes, the sound trailed the video by about 4 seconds!!!
your audio is out of sync because it is recorded with a variable bitrate. to fix this use vdub. open file then go to audio. check full processing mode, then go audio/conversion check 44100, 16bit high quality, stereo. save the new wav or save the whole avi but use video/direct stream copy.
SOLVED:Mpeg2 Video (Movie cilp) to PAL DVD - sync prob using DVDFlick.....
By bahjan in forum Video Streaming DownloadingReplies: 0Last Post: 20th Aug 2010, 10:03 -
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 09:32 -
audio sync prob dazzle dvc-150 and virtualdub
By zephxiii in forum Capturing and VCRReplies: 5Last Post: 30th Jul 2007, 13:34 -
AVI audio prob or video
By SilverDales in forum Video ConversionReplies: 8Last Post: 25th Jun 2007, 15:50 -
audio sync prob AFTER burning !
By bluraid in forum Newbie / General discussionsReplies: 5Last Post: 21st Jun 2007, 05:28
