I have some tv shows I want to convert to mpg from avi, they are only 20 minutes each, is it possible to put more than one on each disc?
And if so how?
I use nero to burn the vcds.
Originally Posted by Puggsley456
Nero isnt a very good encoder, as im sure someone will reiterate.. (they always do)
Better answer.. Convert them with TMPGenc.. then burn with Nero 8) -
I plan on encoding with TMPG but after they are encoded do I just drag them over in nero and make a list of what i want to burn on each disc?
When burning will there be a gap between the different programs when I play the vcd back on my dvd player? -
Yep, just dragging them in will work.. As for the gap, you can specify that in Nero.. from 0 secs up
Even when set to "0", I find that there is a noticable pause between tracks (MPEGs). But, this is only from trying three different DVD players.
Even when you set the gap time to "0", there will still be a small gap.
Regards.Michael Tam
w: Morsels of Evidence -
When I try to exyract the audio usind virtual dubb, It wont let me save the wav file her is what the file information says:
Sampling rate: 22050Hz
Chanels: 2(stereo)
Sample Precision 0-bit
Compression unknown(tag0055)
Preload Skew 166 samples(0.01s)
# of frames 34005
Min/Avg/max/total frame size 157/166/167(5515k)
Any help on how to extract these files would be a great help.
Blu Ray and burning a Data Disc...not a Video Disc
By Moontrash in forum DVD & Blu-ray WritersReplies: 16Last Post: 16th Dec 2019, 22:18 -
Can VOB2MPG Pro combine VOBs from two disc into one mpg file?
By buzzworm in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2012, 16:22 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 14:48 -
Pioneer DV-400V Any way to play standard MPG/MPEG-2 files from USB or disc?
By flobie11 in forum DVD & Blu-ray PlayersReplies: 7Last Post: 2nd Feb 2008, 06:09 -
HD-DVD - MPG/AVI/WMV data disc support?
By Tiernan in forum DVD & Blu-ray PlayersReplies: 2Last Post: 27th Dec 2007, 11:58
