ive been trying to change divx & smr movies to vcd & svcd to play in my dvd . I have a Zenith DA3520 dvd/mp3/cd player.
ive been using TMPGEnc and virtual dub and been burning with easy cd creator platinum. first i tried svcd made from divx but didnt play in my dvd. Now im trying vcd. this site dosnt have compatibility for my dvd player so i dont know which will play. Anyone have any ideas? or any better programs to use?
Are you sure your dvd player can play vcds?
Or you may have to try different types of cds. And make sure you have converted the files properly.
