Hi there im just wondering if anybody has suggestions on what type of capture card to get,i want to be able to record from vcr,analog tv and cable and also digital cable and a dvd player,is this all possible on one card and what do i need to do to do it.
Thanks,suggestions are appreciated
Results 1 to 9 of 9
Originally Posted by rayneeny
I want the best video capturing card!!! So I want to go about $ 500 as the highest amout!!! what can u recommend me???
I am also in the process of moving into capture. These are my choices. I have ordered
Pyro ProDVD MAJOR PRICE DROP! Now $109.95!!!
w/ Ulead DVD Workshop & Media Studio Pro Director's Cut
http://www.videoguys.com/pyroprodvd.htmlI think this is a bargain considering the soft... got mine herehttp://www.nxgenstore.com/nxgen/itemdesc.asp?ic=77010072100 I like the idea of analog or digital..not knowing which I will want to download into the computer at any given time.
Add price of these items and you are well under the $500 with outstanding user endorsement ! ...Now I just hope it works as good as everyone says...Jim -
The Pyro Pro DV with Canpous ADVCD-100 is an excellent setup. Arguably the best afvailable. In particular, the Canopus ADVC-100 is solid gold. By far the finest analog DV capture card on the market. NO setup hassles, no dropped frames, and rock-solid audio sync. (AVOID all the Dazzle products. They're s***.)
Howefer, bear in mind that if you buy a firewire card you will NOT be able to use VirtualDub in any way, shape or form. VIrtualDubwill NOT capture from a firewire card and VirutalDub will NOT open the AVI files authored by Ulead Media Studio Pro 6.X.
You may want to complain loudly and continuously to the author of VirtualDub until he fixes his grossly defective software. -
Originally Posted by xed
Considering that Virtual Dub is Freeware and done out of the goodness and generosity of the authors heart, maybe a polite and courteous suggestion would be more appropriate. In many users opinion, Virtual Dub is the finest .avi editor/capture program on the market and it is free!
Ego -
Take a look at the Hauppuage PVR-250. With the latest drivers and a tweak via graphedit, it's tough to beat. Office Max has them with a $50 rebate right now, so they only cost $100 after rebate.
Originally Posted by Ego_Shredder
Not to mention, NO WHERE IN ANY OF THE VDUB DOC'S DOES IT SAY VDUB IS DESIGNED TO WORK WITH FIREWIRE. You want to capture from firewire, you use a program DESIGNED to work with it, else don't use firewire. Complaing that a program DESIGNED to work with analog capture cards won't capture firewire is rediculous. -
Hmm. This question has never been asked & answered before I'm sure :P But what the heck, good and cheap? Just about any card with a BT8x8 chipset on it, or spend some serious money and get something that might hardly make a difference in the end, depending on source quality, and what/how you convert it to... Search threads, and you'll be reading for months.
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 12:27 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 16:13 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 10:45 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 10:51 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 17:15
