www.tigerdirect.com has the HP DVD100i DVD+RW Drive for $179.99.
It may not be the best, but for the price, it may be worth looking into.
mwh99
Why buy the 100i at $179, when for $20 or so more you can get a Memorex branded unit that will write to +R as well as +RW? In fact, why not spend the extra money and get the Sony DRU500a that will write to +R/RW and also to -R/RW for about $350?
well the price on the hp dose look good but you will have to buy the expensive dvd+rw disks. the sony is prob the best way to go if you are able to add the extra dough. if not i would look into a burner that burns dvd-r/w. because the dvd-r is the cheapest media. you can get for like 60 or 70 cents each if you buy in bulk. instead of 3 to 4 bucks a pop for dvd+rw...
Seriously now. This dvd+rw is only for stupid people who dont go to this website or know what is going on.
This drive is a relic,I'm going to wait a few months because several companies will be making 4x multi-format DVD writers causing the prices to drop.
DVD exploding inside the drive from a drive exceeding 24x. True?
By snafubaby in forum MediaReplies: 10Last Post: 5th Dec 2010, 19:05 -
Is using a Bluray drive better than a regular DVD drive?
By imfallen_angel in forum DVD RippingReplies: 14Last Post: 20th Mar 2010, 21:49 -
Cannot burn to a DVD disc and DVD RW-drive changed to CD-drive after copy
By coody in forum DVD & Blu-ray WritersReplies: 0Last Post: 13th Sep 2009, 05:18 -
Time/Date Stamp - DVD, Hard Drive, and/or flash drive camcorders
By vanjh9 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 2nd Feb 2009, 19:38 -
Lite-On drive LH-16W1P DVD-DL drive
By snafubaby in forum MediaReplies: 8Last Post: 28th Apr 2008, 16:00
