im not too good at making svcds/vcds...... anyway, i use tmpg to make my svcds, but when i burn them and play them on my dvd player, the movie, NOT THE AUDIO studders at times..... can someone please help me avoid this problem???
You could've selected the wrong field order or you could've burn your file at a very high speed.
Hope That Helps!!!
:P
Another stutter possibility is that you encoded your output to 16:9. This makes all Apex players I have tried stutter.
so should i burn it at 8x or lower?
___________________________________________
i did encode it at 16:9.......i have a SAMSUNG 301 dvdplayer, what should i encode it at to avoid stuttering? -
4x max burnOriginally Posted by TheeNotoriousOnee
just to avoid confusion, i think Digifreak stated that if you set your OUTPUT video to 16:9, instead of 4:3 for standard TVs that it may also cause stuttering w/ Apex players....if you set your SOURCE aspect ratio as 16:9, then it wouldn't matter in this case about the stuttering -
Don't know if your player is 16:9 DAR flag compatible, many are not. To test it, set your output to 4:3 (keep input settings the same) and encode and burn a short sample. If it doesn't stutter, then the 16:9 DAR flag is your problem. If it still stutters, you may need to swap field orders if the source is interlaced. If it is a progressive source, make sure you have 3:2 pulldown for output. If the 4:3 output test plays OK, to correct this, encode settings will depend on your source and what you are watching it on. Here are some scenarios:
Source 16:9, TV is 16:9 or TV is 4:3 with 16:9 enhanced mode, encode 4:3 source and 4:3 output. This will display on your TV with correct aspect but will have incorrect aspect on PC.
Source 16:9, TV is 4:3, encode 16:9 source and 4:3 output. This will add black bars to the top and bottom of the encode and give the 16:9 movie the correct aspect on your 4:3 TV as well as your PC.
Source is 4:3, TV is 4:3, set both source and output to 4:3. This will give the correct aspect on 4:3 TV and PC.
Source is 4:3, TV is 16:9, encode source and output both at 4:3 and use the 4:3 mode on your 16:9 TV. This will not display with the correct aspect on PC.
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 06:18
