Hi all,
I downloaded an AVI movie and want to play it with media player (6.4).
The picture is fine, but there is no sound.
Media player tries to download an audio codec but can't find it.
How do I find out what compression was used for the audio?
Other movies and clips play fine.
Thanx for your help, Gijs.
Load the video in Virtual Dub. Select File-->File Information.
Hello. -
sometimes it happens no sound you have only too install nimo or tsunamie codec-pack u can download it from www.divx-digest.com
OK I looked with Virtualdub.
For audio it says: sampling 44kHz, 2 channel, 26-bit.
The compression is "unknown (tag 0161)"
Does that mean anything to you? -
Could also try Kristal Studio Codecs:
http://home.quicknet.nl/qn/prive/ky.tsang/software/codecs.html -
Download GSpot. It tells you what the codecs are even when you don't have them yet. Let's see if I can produce a link...Originally Posted by kersen
http://www.headbands.com/gspot/
There we go. :P
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 15:10 -
Audio Codec after Synchronization
By Aurlito in forum Software PlayingReplies: 0Last Post: 13th Mar 2010, 11:47 -
VD Complain Audio Codec Not Installed
By ks47 in forum Newbie / General discussionsReplies: 2Last Post: 19th Oct 2007, 11:46 -
need mpeg audio codec?
By tomm2000 in forum Video ConversionReplies: 7Last Post: 7th Sep 2007, 21:34 -
Audio codec for dvd player
By mach in forum DVD & Blu-ray PlayersReplies: 1Last Post: 1st Aug 2007, 15:14
