Hello
I captured 2 hours of video into 2.5Gb MPEG2.
I see the movie on the PC, where I captured it, but on many other places I hadn't succeed with it. XP Movie maker could not import it.
I tried to split the file with winzip and reopen it on another pc, but the file could not be opened.
do you know of special formats that XP uses in creating the mpeg2 file.
what can be the reason that ?
thanks
Shai
The format of the mpeg-2 file has nothing to do with XP but is dependant on the encoder that created it. From what you say I guess it was an encoder that came with your capture card. In order to play it back on another PC you need to ensure an mpeg-2 decoder is installed, these do not come as part of a standard windows installation unlike mpeg-1 decoders.
If you want to spli the file to burn it onto multiple CD's in order to move it to another PC, I would suggest using the merge and split utility of the Mpeg tools in TmpGenc.
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 20:16 -
AVI files make DVD huge
By dishwater63 in forum Authoring (DVD)Replies: 6Last Post: 13th Dec 2010, 20:09 -
Making XVID videos with VirtualDub: output files w/huge file sizes (~1GB+)
By maskingtape in forum Newbie / General discussionsReplies: 11Last Post: 5th Mar 2010, 00:50 -
Help me reduce these huge video files! How does the "scene" do it
By AnitaPeterson in forum Video ConversionReplies: 10Last Post: 9th Dec 2009, 19:32 -
Huge avi files in Virtual Mod
By KayAt in forum Newbie / General discussionsReplies: 3Last Post: 25th Oct 2007, 20:08
thanks
