I am capturing AC-3 WAV files from the RCA Digital Out on my cable box.
By selecting Surround as opposed to Digital Surround, I get an uncompressed PCM audio which is a valid AC-3 wav from the Digital Coax connector. Motorola cable box.
The problem is an intermittent static and occassional short silences in the audio. I hear this in the original audio as well as the captured file, both before and after conversion. These defects are not present in the analog sound output, and they are present about 50% of the time. I have recorded 90 minutes or more without error, but that's not common.
My only playback device is my computer, however, and I am concerned my cable provider will insist that is the problem. I hope soon to get a 5.1 amp setup but budget is extremely limited.
I should note that the static usually continues for an hour or more, the silences are one or at most two seconds or less, I don't think I have had any silences when the audio is not clear so they seem to be linked. Have turned off all appliances and/or made sure no changes occur when problem starts or stops.
Has anyone experienced similar problems with Digital Audio or a Philips Acoustic edge, or suggest any testing/diagnostic/repair options?
Results 1 to 1 of 1
Capture from camera-no sound
By Mållgan in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 11th Jan 2011, 11:43 -
Problem:Using Video Capture Card for capture or spy another PC.
By gmchn83 in forum Video Streaming DownloadingReplies: 1Last Post: 15th May 2009, 15:56 -
EasyCAP 2.0 USB = No Sound on Capture????
By williamgibbs in forum Newbie / General discussionsReplies: 0Last Post: 24th Feb 2009, 09:15 -
No sound problem - internal tv capture card
By planetx in forum Capturing and VCRReplies: 1Last Post: 5th May 2008, 05:38 -
pinnacle 11 - sound capture problem
By lhg033 in forum Capturing and VCRReplies: 3Last Post: 1st May 2008, 20:56
