I've tried to search the forum, but for some reason it don't work. What is the best DV codec for capturing video from a miniDV-cam in Premiere? I have seen some posts that mentioned Mainconcept DV codec, but what about Canopus and Microsoft? What I want is the best quality, but I do not want to save the video totally uncompressed.
canopus only comes with something else bundled together. I forget what the name is though. Main Concept looks good.....except I get lots of drops. You may have better luck on your machine.
If you have the latest DX version, you should be fine. It contains the MS codec for DV. That should at least get you started.
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
Which codec
By Tafflad in forum Video ConversionReplies: 2Last Post: 25th Jul 2011, 20:58 -
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 15:10 -
How can I tell which codec is being used?
By sasuweh in forum Video ConversionReplies: 4Last Post: 8th Nov 2010, 01:08 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 20:40 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 10:41
