I own a Panasonic RV-32 (European version) Does anyone know any kind of hack or region changing thing for this machine? I fact, all types of hacks are wellcome!![]()
Have Phun!
-RavedoG -
AFAIK, this machine can only be made region free via a firmware upgrade. This firmware is not generally available but many independant retailers will have it, so try asking around. They may charge a small fee however.
RavedoG:
If you don't wan't a firmware upgrade you can try renting a "chipped remote" that will make your RV32 multiregion, check the info at:
http://www.shoyle.f9.co.uk/dvdchipsuk/nosolderpannyremote.htm
Also try the excelent hacks on the VCDHELP hack page at:
http://www.vcdhelp.com/dvdhacks.php?dvdplayer=panasonic+rv32&DVDselect=&Search=Search
Don't be afraid of trying new combinations. You can fix all the problems related to configurations changes with the RESET SWITCH trick also found on the RV32 hack page.
Good luck! 8)
Panasonic SA-HT940 Hack
By Moridin77 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 6th Feb 2011, 02:00 -
Panasonic S26 hack?
By Judolf in forum DVD & Blu-ray PlayersReplies: 6Last Post: 30th Jul 2008, 08:52 -
Hack for Panasonic PT-SC650
By brunohc in forum DVD & Blu-ray PlayersReplies: 2Last Post: 19th May 2008, 10:51 -
Panasonic S53 - Region hack
By veloz in forum DVD & Blu-ray PlayersReplies: 1Last Post: 9th Aug 2007, 13:31 -
Panasonic S77 Hack?
By merlin001 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 29th Jun 2007, 19:13
