Has anyone tried pinnacle 8 , how is it and is it worth the purchase,![]()
It is an easy to use package with very high quality title and effects capability. The encoder is still the big drawback. For VCD and SVCD, it has ton's of artifacts, and no way to frameserve (ie avoid using the internal encoder).
If you are after simplicity, this is a pretty good package -
It is a very good entry-level package and is very intuitive to use. I use it for editing home movies - I tend to use TMPGEnc to convert my movies to SVCD since it gives me much better quality results than using Pinnacle's own encoder. You can purchase Studio 8 for £52 (if you're in the UK) from amazon.co.uk - there's currently free delivery if you purchase over £39.
Good luck.Mantisgeek -
I just wanted to thank you for your input in this matter ,solid information,
again ,,,Thanks
Pinnacle - work in SD and finished output in HD?
By Ronan Carley in forum EditingReplies: 2Last Post: 31st Jan 2012, 08:24 -
Pinnacle problems
By higgins327 in forum Capturing and VCRReplies: 21Last Post: 30th Mar 2011, 12:31 -
Capture with DC 10 Pinnacle Card with OS Win 2k and Pinnacle studio11
By fjmr in forum Capturing and VCRReplies: 2Last Post: 7th Apr 2008, 17:02 -
Pinnacle 11
By m baqar in forum Authoring (DVD)Replies: 1Last Post: 3rd Apr 2008, 01:08 -
Is anyone using Pinnacle Studio 11 ???
By maxtrack in forum Newbie / General discussionsReplies: 2Last Post: 15th Aug 2007, 22:56
