Thought I read somewhere that PRINCO DVD-R's are good quality?
I bought a spindel 50 pcs DVD-R certified 1-speed in a local store, and the shop-owner told me they could be burned at 2-speed.
Seems that my friend, who bought his disks in the same store, can burn the discs at 2-speed with his Pioneer 04 writer.
Using different burnproggies my Sony won't write them at more then 1-speed![]()
Anyone else got more luck?![]()
Seems there are Princo's certified 2-speed? Saw them in an online shop...
-BK-
Results 1 to 30 of 30
Trying to find good media to burn at 2-speed or faster...
Anyone tried to burn DVD-R's from http://www.cdr-by-mail.co.uk/acatalog/CDR_By_Mail_DVD_R_21.html with a SONY DRU500?
-BK- -
After one batch of Prodisc 2X DVD-Rs worked with my DRU-500A, I ordered 30 (different vendor and first ones were a few months old - different batch.Originally Posted by -BK-
The new batch all failed.
I am getting them exchanged for 30 2X Princo DVD-Rs (since they had sent me a Princo 2X sample which burned at 2X with my DRU-500A and RecordNow). -
I have 200 Princo 2x DVD-R with white thermal printing surface that the DRU500 wont even burn to. I've tried every buring package out there.
The unit just keeps spitting them out.
The same DVD-R's burn excellent in my Pioneer A04.
I can burn other brand DVD media in my DRU500 but not the Princo.
Called Sony, they said that the DRU500 doesn't support that media.
Steve -
The Princo 2X DVD-R discs that I burned to successfully have a GLOSSY white top (just like the top that some of the DVDPro discs have).Originally Posted by -BK-
Is it white with "PRINCO DVD-R For Data & Video General 1x 2x" pressed on it?Originally Posted by VEFF
-BK- -
It does not have any writing on it.Originally Posted by -BK-
Just a white glossy top. -
Seems there are different PRINCO's 2-speed on the market!?VEFF:"Just a white glossy top".
Here in Belgium they are labeled "For Data & Video 1x 2x" as described above. Wasn't able to test them yet...
-BK- -
I would not be surprised if that were the case.Originally Posted by -BK-
I hope they work for you. -
I just bought 25 Princo disk with white glossy on top and none of them work. It's only 1X. I got it from here: http://www.allmediaoutlet.com/P-DVDR-4.7-GENPrinco.html
I got 5 coasters from them. I'm searching for some cheap 2X media.
Some said this works on the Sony DRU-500A at Meritline:
http://www.meritline.com/mer47dvmed2x.html
I might order 25 to see. -
try the new frim ware update which is to support more media and increase the Write speed. There are some forms that discuss this in here.
I just tested Princo 2x (White top + printed: "For Data & Video 1x 2x" on it) sold in a local shop in Belgium...
They won't burn at 2-speed using RecordNow/Nero 5.5.9.17
I already updated my drive with the new firmware.
Is there anyone who was able to test Whitelabel Generation 4 DVD-R 2x compatible???
-BK- -
I just updated my firmware and still no luck with Pinco 2x Blank White Top.
I get them from http://www.tapeguys.com/ for $2.97CAD/disc in a pindle of 90.
These DVD's are great. They work perfect in my A04 and play on every set top that I've tested. This sucks that the Sony won't even try to write to these. -
I just bought 20 DVD-R Princo with label For Data & Video 1x 2x for 2€
and had no problems with my Sony DRU-500A they even burn 2X with no problems.
I have update the firmware and i have one Ata 133 Raid Controler just for the DRU-500A
Specs: Athlon 2200+ / 512Mb DDR333 / 120GB / Geforce Ti 4600 128Mb / Thermaltake XaserII / DVD-Rom Panasonic / LG CDRW 40*12*40 -
Which program did you use to burn the DVD's?Originally Posted by xblade
Where did you buy the 2-speed PRINCO's? In Europe or in USA or elsewhere? There seem to be different PRINCO's 2-speed on the market as I mentioned before
-BK- -
I bought the princo DVD-R 1X 2X in Portugal (europe) and the program that I use is DVD decrypter and NERO (Last Version) they both record at 2.0X-2.1X variable.
Did anybody tried these recently after 1.0d firmware ?Originally Posted by g00kster
I burned successfuly on Princo disk from Meritline.com (white top) but I am not sure if these from Allmediaoutlet.com are the same. -
After upgrading to FW1.0d I have problems with burning the Princó DVD-R 2x. Nero failed at half the disc an Alcohol version 1.3.5.1125 Failed to Finalize the disc.
Alcohol did work with version 1.3.4.xxxx (Burning was finished 100% and tested the DVD-R OK but Alcohol hung after finishing the disk.)
With the supplied recordnow however I did a DVD-Copy at 2x and that worked without any problems.
Also I have some Princo DVD-R´s of the same batch that the burner simple does not recognise. -
:P Kewl! :P
Just bought another cakebox of 10 PRINCO 2x discs in a local store here in Belgium.
These discs have a white glossy top with print on it, saying: PRINCO - DVD-R - DVD Recordable Disc - For Data & Video - General 1x 2x - 4.7 Gb.
Just tested 4 pcs. with RecordNowMAX 4.5 on the DRU500A firmware 1.0d and guess what???
They all burned at 2x !!! Even seconds faster then the CHOICE 2x I used untill now :P
/me happy now !!
PRINCO's 2x cost € 1.50 over here
-BK- -
Looks like peaople have still mixed results...
Wha I am looking for is if anybody tried these (and exactly these no 2x or .... I don't know...)
from Allmediaoutlet.com and only from Allmediaoutlet.com (not from meritline or any other store
after 1.0d firmware (not original firmware) ?
Thanks. -
donpedro,
I got 25 Princo glossy white topped -R's delivered from allmediaoutlet on Monday and have burned 4 with Nero (???.171) and 1.0d firmware without a problem.
They are 1x and will only burn at 1x w/ Nero. I haven't tried other burning s/w.
lewijo -
Sorry to ask again (Just trying not to waste money)...Originally Posted by lewijo
Was it this link ? http://www.allmediaoutlet.com/P-DVDR-4.7-GENPrinco.html -
donpedro,
Yes, exactly the same item & price. So far, I'm happy with both the media and the Sony. -
Here is result. IT WORKED !!! I upgraded to 1.0f before, but I believe that it would work with 1.0d anyway.
I upgraded firmware to 1.0f and the Princo burn now. Aaaaaah. Thats better.
Princo 2x Rated from www.tapeguys.com
Using Record Now DX. Nero no longer recognises my Sony. Waiting for the next version of Nero.
Steve -
Am I blind ??? I don't see any Princo there....Originally Posted by scross28
Panasonic DVD & USB & SD Card Slot Problem
By Tim Sage in forum DVD & Blu-ray RecordersReplies: 1Last Post: 20th Mar 2011, 19:23 -
This Old Princo
By hech54 in forum MediaReplies: 10Last Post: 16th Oct 2009, 18:01 -
Noob Troubles: DVD w/ Multi-Angles & Commentary + m2v & ac3 joining
By ssfblue in forum Newbie / General discussionsReplies: 5Last Post: 28th Nov 2007, 12:54
