Receive this error when trying to add an extracted mpeg to a new project
"GNU VCDImager only accepts/analyzes multiplexed program streams (video AND audio streams) and MPEG Stills"
Mpeg plays fine under WMP..... video and audio in sync.... any ideas?![]()
Just tried simple multiplexing with TMPGenc ... try to enter my mpeg file as a source fro either video/audio... receive error message "illegal Mpeg video stream" ... or "illegal Mpeg audio stream" Regular multiplex tab won't add the file at all...
any ideas?
After spending the last five hours... go over various programs and steps I finally found the best solution... Re-encoding with TMPGEnc only made the source look more pixelated even at the same bitrate... so I chucked that idea out the window... Finally I came across VCDgear... damn lifesaver is what it is... All it took was a quick check on Fix Errors box... and another under options menu to disable "split mpeg" feature and I had a copy of the original mpeg that looked the same, had no sync probs whatsoever, and it VCDeasy would finally accept the damn thing...
Highly recommend this tool as I could have saved 6+ hours fidgeting for 2 min time of decoding/converting.....
Hey chocco - Good on you for having the decency to post your solution for others too see. It's a shame that so many others don't do this... Much kudos to you.
There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
.dv movie project conversion to MPEG-2 with video text
By RL in forum ffmpegX general discussionReplies: 1Last Post: 30th Jan 2011, 17:39 -
add a video_ts project a mpeg file
By simor in forum Authoring (DVD)Replies: 2Last Post: 29th Nov 2010, 15:50 -
How to convert DVD project to Blu-Ray project??
By zentsang in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Jul 2010, 17:08 -
Help with Business Project - PDF/MPEG on a Disc
By mn072065 in forum ComputerReplies: 8Last Post: 19th Nov 2008, 20:44 -
what pixel aspect ratio to use when making mpeg titile for DVD project
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 26th Oct 2007, 04:49
