I am trying to format a Video clip, it is a movie that i have on my computer, i want to convert it so that i can watch it on my personnal dvd player to watch on my tv.
does any one know how i do this? here are the facts about the file in the property:
Type of File: Video Clip
Audio format: MPEG Layer 3
Audio bit rate: 96kbps
Video rate: 62kbps
any help would be great
thank you
Yes, use this guide:
http://www.vcdhelp.com/divxtovcd.htm#audio
You, most likely, have a DivX AVI file and it is always best to install Nimo Codec Pack to allow TMPGEnc (or any other preferred encoder) handle them properly.
I have to warn you though that your final movie's quality won't be the best since your DivX video is 62Kbps (100Kbps is a decent quality), as the saying goes crap in crap out.
Sync/align one short clip into one big clip
By diamondback in forum AudioReplies: 1Last Post: 2nd Nov 2011, 10:31 -
Do I need to stop clip analysis in order to export clip for dvd
By maevek1 in forum MacReplies: 0Last Post: 9th Apr 2008, 09:26 -
can't find a video clip
By namsilat in forum Authoring (DVD)Replies: 2Last Post: 11th Nov 2007, 17:22 -
d/l trailer (video clip) but no video just audio
By leinan in forum Newbie / General discussionsReplies: 0Last Post: 25th Jun 2007, 01:33
