I used Camtasia Studio to capture some "how-to-use-this-website" stuff as an AVI screen capture.
When I coverted this AVI to MPEG-2 with TMPGEnc 2.5, and burned to SVCD with Nero, the resulting video had a lot of flicker on my TV.
I tried combinations of the following settings in TMPGEnc, but none of these seemed to reduce the flicker problem:
- Inverse telecine 30 fps
- Inverse telecine 60 fps
- Ghost reduction
- Top field first
- Bottom field first
- Encode mode: interlaced
- Encode mode: non-interlaced
For the record, the orginal AVI file was produced with Camtasia at 5 fps and also at 30 fps.
Anyone know how to get rid of this flicker problem?
UPDATE:
I ran the AVI file through Premiere and used the remove flicker option. I then outputted to TMPEGenc and made a SVCD. The flicker didn't appear on the TV.
So, that appears to be the solution. But for those w/o Premiere, is there any way for TMPEGenc to remove the flicker?
Best video capture software? Is AVI better for capture? Is TV screen better
By johnharlin in forum Capturing and VCRReplies: 5Last Post: 21st Feb 2011, 07:17 -
View output from video capture card
By kkpatel87 in forum Video Streaming DownloadingReplies: 2Last Post: 23rd Jul 2009, 19:30 -
screen capture output to dv stream
By bissquitt in forum Video Streaming DownloadingReplies: 12Last Post: 27th Jun 2008, 03:22 -
Screen flickers after updating my Asus BIOS
By Hittz in forum ComputerReplies: 8Last Post: 18th Feb 2008, 01:38 -
Is Pyro's S-video output an accurate representation of capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 14th Sep 2007, 16:41
