does anybody know how to make an exact copy of a recordable dvd-video disc?
Results 1 to 9 of 9
If it's a DVD-R/RW, +R/RW then use nero and do a DVD Copy.
If it's a Comercially pressed DVD, you can't do a 1to1 copy -
i tried nero burning rom 5.5.9.0,
that program does not let you make an exact copy of dvd's only cd's. -
that program does! i use it every day! goto dvd on the left top look for dvd copy click it hit copy then it will open your drive and insert the dvd after a while insert the blank
okay, so i duplicated dvd-r video sucessfully with nero burning rom.
now i would like to know how you can burn it faster then 1x,
cuase nero limits the speed to only 1x.
my pioneer burner can burn up to speeds of 2x -
You need to upgrade the firmware. You can do that by downloading the appropriate file here http://81.97.231.148/pioneer2x4all/ If you want to burn at 2x you need to be using decent media.
that firmware program does not work.
why would i need to upgrade the firmware, when the advertised speed of the burner of a04 is already 2x., its just the nero program does not have an option to burn it at 2x.
does anybody know of a program that will let me make an exact copy of a recordable dvd-video disc at 2x? -
Nero burns with 2X. Download the new Version of Nero, I think 5.5.9.17 is the newest one. Nero offers you 2X-Speed when you insert a 2X-compatible Media.
You need the new firmware, because the DVD-Forum changed the specification of 2X-DVD-R after the A04 was released. If you have Firmware 1.3 or higher, you do not need to upgrade. I have 1.30 and it works fine.
My Dvd Video Disc is Protected, Couldnt copy the files..... ^_^
By syaoran7li in forum DVD RippingReplies: 21Last Post: 20th Apr 2012, 21:05 -
Exact Copy of DVD made in Poland from Hard Drive of LG recorder
By dubronidog in forum MacReplies: 5Last Post: 18th Nov 2010, 10:14 -
Exact copy of a DVD to a container playable in itunes
By jamsponge in forum DVD RippingReplies: 5Last Post: 20th Jan 2009, 11:19 -
How to make exact screencaps easily from DVD?
By zee944 in forum Software PlayingReplies: 30Last Post: 8th Aug 2008, 04:06 -
how do i copy DVD RAM discs to pc hard drive (retaining exact file quality)
By mnbvc in forum Authoring (DVD)Replies: 3Last Post: 19th Apr 2008, 18:32
