Why is it in the guide to convert .vob files with Dvd2Avi it has a lot of options, but when I download it, it doesn't have everything the features the guide has. Can someone tell me whats wrong?! Thanks
I had the same problem (not with the same program). The problem can be that the versions are different... Either they did the walktrough with a version and by misstake wrote the wrong version number or the source of dl is housing a old version of the program...
If this does not solve the problem, maby there is an button for advance/expert use? I never tested the program my self so...Have Phun!
-RavedoG
Correct AR(aspect ratio) on dvd2avi conversion (16:9 vs 1.85:1)
By Visual-Artist27 in forum DVD RippingReplies: 10Last Post: 19th Aug 2010, 23:11 -
DVD2AVI/DGIndex Aspect Ratio Problem (Long/Stretched Faces, etc)
By munkeyman in forum DVD RippingReplies: 7Last Post: 19th Feb 2010, 09:47 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
How to frameserve (dvd2avi / VirtualDub / Avisynth / VFAPI)
By Truman in forum User guidesReplies: 32Last Post: 20th Nov 2007, 08:38 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
