Bilestyle,
Couldn't resort to a virtual PC solution. Too stubborn =)
Purchased qt6 pro and the required encoder but still having problems:
when trying to start up afro pic( using elementary streams ripped via osex)
I get an applescript error indicating an error -61- file not open with write permission. Have had a little success- one started the process until the following message was reached:
error (mplex) unable to open file "thefile.m2v"for reading
Your thoughts?
Tia
Skingjack
Results 31 to 33 of 33
the -61 applescript error is becuase it tries to write the command to shell script embedded in the program before it even runs... so if you want to run afropic you need to copy it off the disc image (for now..) the other error i couldnt shed much light on with that amount of vague information.. and i hope you bought the mpeg2 DECODER for quicktime and not the encoder... not that i think they sell the encoder seperate... pretty sure only with dvd studio pro... anyways-- let me know more info and ill try to help
As below, so above and beyond, I imagine
drawn outside the lines of reason.
Push the envelope. Watch it bend.
Over thinking, over analyzing separates the body from the mind. Withering my intuition leaving all these opportunities behind. -
Bilestyle,
Below is the output after running afropic on the movie "Trinity is still my name":
MP2 Encoder: This might take a few minutes...
MP2 Encoder: INFO: [mp2enc] Opened WAV file, freq = 48000 Hz, channels = 2, bits = 16
INFO: [mp2enc] format = 0x1, audio length = 2030043099 bytes
MP2 Encoder: INFO: [mp2enc] slots/frame = 731
INFO: [mp2enc] frac SpF=0.429, tot bitrate=224 kbps, s freq=44.1 kHz
INFO: [mp2enc] Fractional number of slots, padding required
INFO: [mp2enc] System is big endian
INFO: [mp2enc] Avg slots/frame = Inf; b/smp = Inf; br = Inf kbps
INFO: [mp2enc] Encoding with psychoacoustic model 2 is finished
INFO: [mp2enc] The MPEG encoded output file name is "/Users/iwatson/Desktop/TITLE01-ANGLE1-AUDIO1.mp2"
done!
INFO: [mplex] mplex version 2.2.1 ($Date: 2002/04/20 19:08:30 $)
**ERROR: [mplex] Unable to open file call for reading.
rm: They: No such file or directory
rm: call: No such file or directory
rm: me: No such file or directory
rm: Trinity: No such file or directory
rm: audio.mp2: No such file or directory
10:35PM up 59 mins, 3 users, load averages: 0.98, 1.16, 1.15
[G4:~] iwatson%
The question I ask: has the programs quit? I do have the following files as output: temp-1.mpeg and title01-angle1-audio.mp2.
As always, thanks for the assistance.
Skingjack
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 17:56 -
Can I burn VCD or SVCD on DVD±R/W?
By Baldrick in forum Authoring (DVD)Replies: 111Last Post: 30th Aug 2008, 17:38 -
Newbie trying to figure out DVD to SVCD/VCD
By 4194 in forum Newbie / General discussionsReplies: 14Last Post: 26th Aug 2007, 09:34 -
Burning VCD/Svcd mpg files to dvd without encoding
By Morb1ous in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 17:56 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14
