is there n e 1 who could please explain to me the correct way how to convert ntsc format to pal, i have 2 mpeg cd's i would like to convert to pal format b 4 i join and burn to dvd-r, i have read the conversion guides but am a little lost.
Many Thanx
Max
Check out this page.. should give you all you need
http://www.vcdhelp.com/tmpgencsvcd.htm -
i have had a look at the instructions but am still a little stuck, pretty new to this converting from ntsc to pal, never tried it before
all you should have to do is drop the NTSC MPEG into TMPGenc..
hit the load button..
and then select whatever format you want to convert to..
example..
VCD-PAL
VCD-NTSC
SVCD-PAL
SVCD-NTSC
ect.. -
ok will try 2morro, thanx for your help. If i wanted to convert to full screen would i also do this in tmpgenc ???
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 12:34
