Ill give this a try...
Im using a Samsung HI-8 video camera and connected it to my ASUS V8420 Deluxe card with a 4 pin s-video cabel, but i get no sound.
the picture comes out fine and ive tryed all sorts of programs, from ASUS own programs to Premiere and VirtualDub.
Now... im totally new to this so it might just be something i forgot to do or connect, but i would be very happy for all the suggestions i can get. even if it is "sorry dude you cant get sound and video with that shitty card"
cheers
Yes S-video only carries the video signal not the audio. You need to connect up a pair of rca leads (assuming your camcorder is stereo, only 1 lead if its mono) for the audio
if it is... then thats probably the problem
but when connecting the cam to a TV i get sound.. so, im clueless -
ok i got those too.. a white and a yellow, the output from the cam thos those cables says A/V out, but i connected all the cables i could find from the cam to the card and still no sound...
could it be soemthing im missing in the actual setup.. some prefs i should use? -
You must be connecting something other than s-video to your tv to get sound. Like I say if its stereo you will probrably have a pair of rca(phono) connectors, 1 red, 1 white.
If you have a white and a yellow, then it is mono. The yellow is another video cable so if you have s-video connected you dont need to use that. Just connect the white rca cable for mono audio.
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 22:03 -
3d video with dts sound how to convert to ac3 sound
By fredddiemercury in forum Video ConversionReplies: 4Last Post: 2nd Nov 2011, 15:54 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 15:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 12:58 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 19:01
