At Dazzle website they Say does not work with AMD K-7 on another part of there website it say's does not work with AMD Athlon. the AMD 1400 so if it is going to work at all it should work with the newest chip if it does. I never had a AMD chip set so I do not know that much abou them
Best is to ask them direct. I do believe there is a contact email page on their website. Mind you they take some time to reply. It might be better if you ask this question at
http://stop.at/dazzle2
<font size=-1>[ This Message was edited by: aldus4 on 2001-07-04 19:02:20 ]</font> -
I contacted them before and they said that the problem existed with Slot A athlons and early chipsets... the new ones SHOULD work properly... but there are no promises
Also i was told that if you got the Firewire version (Holywood DV Bridge) that it would work flawlessly on an athlon system. Plus i think theyre similar price arent they?
Hope i was of help to you -
AnonymousGuest
i use the dazzle II worked fine with my amd k3 400 and now works fine with my new 1300 mhz thunderbird 266 fsb
[Closed] Vid capture problem- aud/vid synch issues...?(Dazzle VidCreat+HD)
By Diana (Cda) in forum Capturing and VCRReplies: 2Last Post: 22nd Dec 2011, 11:50 -
AMD AM3+ Socket Compatibility?
By wulf109 in forum ComputerReplies: 0Last Post: 4th Nov 2011, 23:26 -
Will all amd quad cores work on a am2 socket? (no + just am2)
By yoda313 in forum ComputerReplies: 25Last Post: 15th Apr 2011, 18:30 -
Dazzle Vid Creator Plus, or TV tuner card?
By cwb in forum Capturing and VCRReplies: 3Last Post: 21st Jul 2009, 09:38 -
INTEL 478 socket - 775 socket heatsink/fan
By blinky88 in forum ComputerReplies: 7Last Post: 7th May 2009, 11:38
