Hi, I’ve been trying to convert my 23.976 avi files to svcd in tmpgenc with ur conversion guide works on my pc everything seems ok til I try to burn it and nero comes up with a message about being an invalid svcd stream, I’ve also tried the doom9 method both with the same results, I turned off compliance it doesn’t play on my dvd player am I missing something
bush 2004 dvd player–Not version A
virtualdub for frameserveing
tmpgenc for encodeing
i used this guide http://www.vcdhelp.com/forum/userguides/78178.php
i did say in my post which guides(that is id there is only 1 on this site) -
Please forgive me if i misunderstood you but that guide is for converting FRAMERATE not encoding to SVCD, did you try to burn your AVI as SVCD with Nero? If you did - that's your problem. AVI has to be encoded to Mpeg2 for SVCD and there's a different guide to follow to accomplish that.
wasn't very clear sorry i've used the guide to serve my 23fps file to 25 and encoded it in tmpgenc with the svcd template when i try to burn the file it gives the above error it does this with and without the audio also with the same results in doom9's guide
try unchecking the "create standard compliant disc" option and burning
or(a better method), use VCDeasy to create an image, and then burn the image w/Nerowhat are you askin' me for...
I'm an idiot!
Frame Rate/23.976 vs. 29.97
By mltwitz in forum Video ConversionReplies: 11Last Post: 20th Dec 2012, 08:23 -
25fps BD with MBAFF to 23.976
By Anonymous344 in forum Video ConversionReplies: 11Last Post: 5th Jun 2011, 19:21 -
Remove pulldown? (29.97 -> 23.976)
By Asterra in forum Newbie / General discussionsReplies: 2Last Post: 5th May 2010, 20:12 -
Difference?? 23,976 pics/s or 29,976 fps
By twanbaten in forum Authoring (DVD)Replies: 1Last Post: 6th Nov 2007, 12:29 -
29.97 interlace to 23.976 progressive
By Alex DeLarge in forum Video ConversionReplies: 5Last Post: 8th Aug 2007, 19:09
