I have a dvd which has 6 episodes, total of 8 gb.
How do I put these on to a dvdr.
chances are you will need to re-encode these episodes to reduce their size. ReMPEG, TMPGEnc and CCEare some of the most popular tools usedf for this purpose. If you visit the how to section on the left you will find many great guides to get you started.
You might consider putting three episodes on a DVD-R,and use two DVD-R's. That way you will maintain the original quality and the process will be much faster.
I put 6 STTNG on one dvdr by encoding with tmpenc using the low res dvd template (352x288 mpeg1 1850 kbs). Authored the episodes with spruceup with a basic menu. The quality wasnt astounding, a bit better than vcd. I elected to forgo the ac3 audio for simplicity.
dilligraf
I've been author TNG episodes 4 per DVD-R at 720x480,3100 average bitrate,ac3 sound. There very close to original DVD quality. I don't really see the point in authoring a DVD to VCD quality. I use Spruce and preserving the ac3 is easy. -
did you use 4 different buttons and link each segment to a seperste button? Basically 4 different or seperate movies on one disk?
Jim -
Yes,I associated each episode with a button in the menu. I also used the opening sequence from the DVD as a first play and captured some of the DVD's menus to ..bmp files and used them as backrounds in SpruceUp.
Yes I could'nt agree more, I was trying to do it on the cheap as the media I'm using is ~$AU10 each............I failedOriginally Posted by wulf109
. My next attempt will be closer to your setting. I'm using the AC3 audio stream on other projects and so will do the same on my next multi-episode dvdr.
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 20th Oct 2013, 00:25 -
DVD to AVI/DVDR and AVI/WMV/MOV to DVDR
By BIFFtheSTIFF in forum MacReplies: 5Last Post: 19th Nov 2010, 13:35 -
What device will enable recording of TV to DVDR and DVD or VHS to DVDR?
By enricomad in forum DVD RippingReplies: 1Last Post: 26th Jun 2008, 18:46 -
PAL DVDR to NTSC DVDR including menus + extras? Is there an easy way?
By junkmonk in forum Video ConversionReplies: 3Last Post: 14th Mar 2008, 00:19 -
Apple Trailers to HD-DVD or BluRay on a standard DVDR/DVDR-DL
By Scooter_NJ in forum Video ConversionReplies: 0Last Post: 21st Feb 2008, 19:14
