Just wondering what I need to do to import the original chapter files to dvdmaestro? Do I need a menu to use the chapter points? I really don't want to build menus. Thanks.
Scotsman
Use Chapter Xtractor v0.961 to extract the chapter list from original IFO and import it in DVDMaestro!
In ChapterXtractor on bottom left, set Presets to "DVDMaestro" then click on Open IFO below. Select the original IFO file and click Open. Click Save data, provide a name, and select DVDMaestro (*.chp) as file type.
In DVDMaestro, import your Assets and place them in the appropriate work area. To import chapters, Right-Click the space between the two timelines (not sure what you call that part...the scrub line? the play cursor space?) Click Import Chapter List... and import the CHP file you've created with ChapterXractor. That's it!
AVCHD (DVD) .ISO file, trying to extract original MKV from DVD image
By SkEvolver in forum Blu-ray RippingReplies: 12Last Post: 11th Aug 2011, 06:55 -
How to add Subtitles to original DVD whitout loosing original subtitles ?
By Chainsaw_1 in forum Newbie / General discussionsReplies: 2Last Post: 6th Jan 2010, 13:52 -
dvd-lab: import chapters
By cL0N31 in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2008, 21:32 -
By SkEvolver in forum Authoring (DVD)Replies: 1Last Post: 3rd Jul 2008, 21:34 -
DVD Import Errors
By tagvideo in forum MediaReplies: 1Last Post: 25th Sep 2007, 10:48
