I'm backing up my copy of Band of Brothers. Each disc is made up of 2 episodes. I use dvdmaestro to build my dvds, but I've only needed to build 1 video file. I read on the forum that what I need to do is make a new movie in maestro and import the second video/audio to the second movie. Here's what I don't know how to do. How do I link the second movie to play after the first movie? I haven't built menus for my videos I've just link maestro to play the video at load up. Anyone know how to link the second video?
Thanks.
Scotsman
krazyscotsman this is your lucky day
i just learned how 2 do it last night, but in my case i wanted a dolby trailer first then main movie all to auto start.
first my typing and spelling is bad so no coments
this guide is very short hand ...saves typing
import the two films .. bottom right, under untitled project delete menue 1(this will make the disc auto play) then add 2nd movie icon
double click movie 1 icon, add film,double click movie 2 icon, add film
1click movies in untitled pro
bring to front of screen ,connection window
under first play right click target, movie,movie 1,movie 1 chapter left click(this will set what movie will play first) 8) now this is the bit you are stuck on
right click movie 1 end action target, movies, movie2, movies2chapter left click( this will make movie 2 auto play at the end of movie 1
8) )
when u have done that do what u usually do for the rest of the project
i hope u can understand this guid .. it works 100% for me
let me know how u go on
cheers & beers -
or you can lay them all out on the same movie line and right click on audio and assign each vid portion to its audio file ..
maestro will all also combine mpeg's with ease and also trim them if you need it to ..
if no menu when first movie ends 2nd movie starts right up .. nothing to set ..
Help In Putting Two Videos Into One Screen
By R3CONF1GUR3D in forum EditingReplies: 12Last Post: 13th Apr 2011, 04:20 -
Putting videos of my band on YouTube
By Wild1 in forum Newbie / General discussionsReplies: 4Last Post: 17th Apr 2009, 19:50 -
putting videos on a Nintendo DS
By Al the Killer in forum Newbie / General discussionsReplies: 3Last Post: 10th Aug 2008, 06:04 -
Putting 2 QT Files w/ 2 seperate .srt files onto a DVD
By whoracle in forum ffmpegX general discussionReplies: 5Last Post: 22nd Jul 2007, 03:57 -
Putting 2 videos together?
By phate53 in forum ComputerReplies: 3Last Post: 3rd Jun 2007, 22:21
