Forgive me if this is a dum question but is it possible to play a DVD in a standard DVD player (Panasonic RV40) via a scart lead into a DVD recorder (Panasonic DMR E30) and overcome the built in copy protection?
NOPE, I know of only one DVD player that will bypass the DVD Keys so you can backup your DVD's that is now the out of print Sampo 631CF, does a great job and I have been able to backup any and all DVD's. I have heard supposely also one APEX DVD player that will also, but APEX is a really cheap machine, Sampo 631CF has a great and stable picture.
I heard that you can use a time base corrector between the two units to eliminate macrovision and other copy protection. I think these units start at about $300 US. Try an internet search
The Sampo 612 and Daewoo 5800 can both be made macrovision free with a simple CDR upgrade.
you can get a cheap scart cable with a macro off function on them for around £30 but U will need to visit a computer fair!! these work by the way as my mate has made some backups using a crappy alba player to his philips dvr
DVD Recorder - Copy-protect
By Maniac100 in forum DVD & Blu-ray RecordersReplies: 19Last Post: 1st Nov 2014, 10:44 -
Can't copy DVD's to HDD on Sony DVD Recorder (RDR-HXD860)
By ShwMae in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 16:27 -
Copy Protection from a DVD recorder?
By tonyaldr in forum DVD & Blu-ray RecordersReplies: 16Last Post: 2nd Nov 2008, 14:51 -
Will a DVD-Recorder to DVD-Recorder copy lose quality?
By blackmetal in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jan 2008, 04:54 -
how to copy my DVD recorder's HD to an external HD
By CdnMark in forum DVD & Blu-ray RecordersReplies: 2Last Post: 6th Nov 2007, 09:49
